Running 305/70/R16
Richmond, Va
Does anyone know what I would need to do to run a 305/70/R16 on my 1994 Land Cruiser without a suspension lift? I would like to do as little cutting as possible. I am fine with wheel spacers and a small body lift. I do have Bilstein shocks. Thanks
Just put on the tires and go. No cutting, no spacers, no body lift necessary unless your stock springs are completely toast. If you do need to lift a little, spring spacers will do the trick.
In the future, try to use the search function before asking your question, because odds are very good that the information is already out there! :) For instance, you would see that some people even fit 315/75r16 onto a stock truck with no lift.
^^what heckraiser says^^ I ran 305/70/16's as soon as I bought mine......now running 315/75/16 MTR's with no lift ....well I am running OME stock height heavies in the front because of ARB/winch/2nd battery etc, plus I had a passenger front spring broken.
Yeah, what they said. I'm running them on a totally stock LX450, and they are just fine.
