Rumble strip shudder
Livermore, CA
2004 GX470 with 140k, 2.5" OME lift and 33" tires.
Yesterday I swapped in new front rotors and brake pads (Napa rotors and Toyota pads). Took it for a ~30 minute pad bed-in drive followed by a few errands. Car felt great and the new rotors/pads definitely fixed my subtle brake shudder.
This morning on my drive to work I started feeling the "rumble strip" shudder at 20-25 mph. Fortunately my commute is super short so I parked it and took a look. Nothing visibly wrong. Thinking it might be something in the VSC / electronic system I disconnected the battery for the morning. Rumble vibration was still there during the drive home.
Observations:
Shudder starts around 15-20 mph. Haven't driven it faster than 25.
No steering wheel shake, no pulling to a side.
No shudder in park or neutral, even with engine revving.
No strange smells.
Still shudders coasting in neutral.
Transfer case seemed a little reluctant to shift between H and L
Is it time to flush the transmission? I crawled under the car during lunch and nothing seemed loose, wobbly or visibly broken. What are some other things I can check while the cars on jack stands? Thanks!
Thanks, that was definitely helpful. It sounds like either the TC is acting up or a binding u-joint. I've been meaning to do a trans fluid exchange so I'll try that first before the drive shafts.
One AT drain and fill seemed to fix the problem for now. Will be doing a few more in the coming miles as the og fluid was GROSS
I had a similar symptom in my truck only apparent at highway speeds; bad wheel bearings. New hub assemblies from Blue Pit fixed it right up.
I had the same thing exactly as you described. I put through 2 gallons of new fluid (drain/fill) to get it flowing clean then added one tube of Shudder Fix. It's been over 50K miles now & the rumble hasn't come back.
