RTT maintenance help needed – Waterproofing and Fabric repair
LandCruiserPhil
Peter Pan Syndrome
Supporting Vendor
Graham County, Arizona
Looking for some feedback on the following:
Waterproofing - I have a Mare RTT from Venezuela and its been a great RTT but it is getting to be several years old. Do I need to re-apply some kind of waterproofing to the outer fabric? The roof itself does not need anything because it’s a rubber membrane of some sort but the sides are some type of canvas. It has never gotten wet inside but I don’t want to find out at the wrong time I should of done some type of maintenance.
Repair – I have two of these little holes 1/8” (see picture) and I don’t know how to go about repairing them. Any suggestion or experience?
i wonder if there is a patch kit available...
using nylon squares and a type of cement....
There is...
I used it on my 4 season mountaineering tent, term-a-rest and has yet to fail on me...
Here are the links...
GORE-TEX Fabric Repair Kit
Seam Grip
Seam Grip Repair Kit - 1/4 oz
On small pin size holes I use the seam grip alone and let it sit for a few days before using it...
I have even used it to seal a tiny hole on one of my camel bags..
Good luck and hope this helps..
Why dont you buy a new one?
I dont think it will work well after repair.
I can introduce high quality roof top tent to you.
Buy a new one...let me think about it:hhmm:....................NO
What do you know about Mare RTT? What tent would you consider of higher quality? I use a couple other RTT and I think the Mare is just fine. Lightest in its class, no flapping in the wind, excellent cover, and uses no wood anywhere, whats not to like?
There is...
Seam Grip
Thanks I think you nailed the hole repair:clap: The Gore-Tex fabric repair sounds like the ticket and it has great reviews. I believe the hole exists because the fabric is tight in that area and a little extra backing will help reinforce the area. I remember the iron on patches when I was a kid, very durable.
No prob...
I would but the patch on the inside of the tent and use some Seam grip on the outside.. a few drops should do the trick. That stuff is awesome...!!
No prob...
Good advice Thanks!
If you want a good seam sealer, do ityourself and it is cheap....
Best I have ever used...All you need is a tube of quality RTV silicone sealer (clear) and mix it with enough MEK or acetone to thin it out so it is brushable. Take a cheap brush, and brush it on the seams. It leaves evidence you have done it but it will not leak.
