RTH - Tips on accessing #6 spark plug needed!
Northern VA
I'm getting pretty frustrated accessing the #6 sparkplug to swap it out.
Any tips for what to move out of the way and what needs to just be removed?
I figured i'd stop a sec to ask the question before I break something or throw my wrench across the lawn. :bang:
Thanks.
Yea its a pain but the water valve is held on by 2 bolts, take those loose & then being careful moved it forward & it may help.
Reason I say to be careful is when I did this job a couple of weeks ago I broke my water valve ends off:doh:
Thanks, pal. That did it for me. But what I found behind "door #6" is something I wish I hadn't been able to get to in the first place.
Oil fouled spark plug #6. :censor: :bang:
I bet you'll soon be in need of a head gasket, sorry:bang:
Pull the engine out, that is how I change my spark plugs
Thats an excellent way to change your PHH to.:cheers:
RescueU is the plug insulator coated in oil or is it actually the electrode.
6 and 1 are a pain. Get different size extensions and try them I think I used 3 diffrent extensions when I replaced my plugs. I also used a short stool.Be sure to gap right mine was.08 and use anti-seize on the plugs. 2 cents MIke
Just the electrode.
Do you know if you are even getting spark?
It does not look like it is even firing?
Is the truck missing?
Maybe I missed it but how are you plug-wires?
MARLIN375 sounds about right in saying it doesnt look like it is getting spark.
I broke the rubber off of the bottom of the boots, anyone know how to remove that?
I dropped the socket in the hole and then used my long extension behind the hose on the water valve. HTH.
Rather than drop the socket down there, i lined it up over the hole holding it in my right hand, and fished the socket extension bar behind the bend of heater hose, then connected it to the socket and lowered it down easy. Key to this approach is loosening the bolts holding both, the wiring loom and the water valve, that secure them to the firewall. The challenge is when installing #6 spark plug. IMHO, you definitely want to secure the socket to the extension bar with some duct tape (and I also advise a little dielectric grease around the plug's ceramic to ease the disengaging of the socket after the plug's all torqued in), so that bit of slack with the water valve is the key. X2 on going easy when pushing it aside. I can see how it could break if forced...not a lot of give there.
X2 on #6 being a PITA, but after doing it for the first time, I can see it being not as bad on the next go now that it's demystified. I'm still trying to figure out when the heck all my extension bars went! They are definitely essential. The duct tape trick is a must.
X2 on checking the gap of the new plugs. The NGK's are listed that they're supposed to be 0.032" out of the box. Yeah, right.:flipoff2: All 6 of my new plugs were ~0.038". At least they were consistent. :rolleyes:
There's a number of places I've read on the web and Mud about which anti-seize (aluminum or copper-based) to use specifically with sparkplugs. Just be sure you use it sparingly to avoid any getting squeezed thru the threads during insertion and into the element side. Bad juju there.
If it was, to be honest, I can't imagine how. I'm wondering if I should pull #6 after a week or so to see if the fouling persists.
Crap! What? It was in the driveway when I went to bed last night!! :lol:
He he, yeah the CEL definitely popped on Cyl #3, but why there and not #6 is a bit perplexing.
Checked all wires for resistance and all were pretty low. But I'm going to swap out for some new OEMs as soon as i can afford them. Peace of mind.
Trying to think how that happened... got and pics of it?
Old brittle boots + used motor to be put in = broken boots on 5 of 6 cyl's.:confused:
The last time I changed them in both of my trucks was during head gasket replacements last year. Yes, two trucks, two HGs, one year. Both were scrubbing on #6.
Anyway, when I had changed them before that, all I used was the tool from the Land Cruiser kit in the cubby beside the jack. It looks like a 7" long piece of conduit or thin wall pipe with dents on one end and a hole through it on the other. It is a spark plug wrench. It has a little L shaped metal wand that goes with it to turn them.
Its slow going to use it for the #6 one as you have to remove the handle about every 1/4 turn, but it works.
IMHO YMMV
