Rth!! Spindle look ok rth!!
Belgrade,MT
Pulled apart front and this is the passenger side spindle, has some wear or rust, thrust washer as a groove in it, bearings look and feel ok. I am replacing bearings and races. to try and solve front end noise as In my other post, that was getting no replys. I am going to remove dust shield and look inside. Is this wear ok? Should I do anything to clean it up.
Replace the washers and polish the spindle with emery cloth. Based on the wear on the washer the outer bearing has been spinning on the spindle. If there is a noticable ledge on the bottom of the spindle you may need to replace the spindle as well.
by ledge wear do you mean, it tapers up in thikness from the front
A spinning bearing makes a distinct ridge on the spindle. It will not be tapered.
The wear on the washer and flat step where the inner bearing rests are from the bearings running loose. My test is to test fit the new bearings on the spindle, they should have a sliding fit, if they have a loose fit, have play between the inner race and spindle, the spindle needs to be replaced.
Properly maintaining wheel bearings is the preventive to this type of damage. They should always be run with preload, if not will be pounded out, damaged. Up to a point, tighter bearing preload is better than loose, especially with bigger tires, higher loads, wheeling, etc. IIRC mine are set at 20 ft-lb on the nut (37" tires).
New bearings will wear/ break in, races can shift, etc, so it's important to recheck preload on them after the break in period. One of the reasons that I prefer to run used bearings, they hold their preload setting much better, as long as they are reinstalled on the same race as broken in on.
So checked fit and looked at the inner birf, looked good on pass side, shaft under spindle pretty dry, brass bushing also not covered in grease. reassembled no play in wheel bearings all new parts bearings races, gaskets thrust washer(claw washer as mr t called it) pulled apart driver side and found dry caked grease in brass bushing grooves on spindle, similar wear on outside as pics above. As this is my dd I am cleaning the inside of the spindle and greasing the sh*& out of it and going to reassemble, cannot remember if I read that the bushings are not available seperately, you have to get a whole new spindle, please tell me I am wrong. I will upload pics of worn brass bushing after I get it back together and drive it.
here is a picture of the scoring in the brass spindle bushing also found a ridge on the bottom of the spindle, looks like I need a new spindle
