RTH - Speedometer gear question
RWBeringer4x4
Mechanically Challenged
The People's Republik of Maryland
Hey all,
I am in the process of putting my transfercase back together and unfortunately I can’t remember how my speedometer housing looking when I pulled it apart!
I have one of the “oil seal” style speedo gear sleeves - it’s not machined for o-rings. That said, the rebuild kit comes with all of the following:
I believe I just knock in the tiny oil seal, and put the large o-ring on the outside of the housing, right? I think the felt and the smaller o-ring are for the other style speedometer housings...I just want to confirm that these don’t need to go in somewhere before I button it up.
Thanks!
Plan seems sound to me.
That housing should have the small lip seal inside of it.
Large oring on the outside.
Lube the seal/oring and install into rear output housing.
Make sure the speedometer drive gear spacer on the transfer case main shaft is orientated with the taper towards the speedometer drive gear, or it will possibly chew up your plastic driven gear.
Ok great, thank you @Poser!
Yes I think I oriented the taper properly:
Last question - when I pulled the case apart, there was a thin “shim” sitting behind one of the staked nuts. It wound up in the bag labeled speedo housing so I’m guessing it might be the stake but on the back of the drum. I don’t seem mention of a shin anywhere nor do I see what good it would do. Any thoughts?
I’m thinking this likely got mis-bagged but it definitely came off the transfercase because I remember it seeming strange at the time...
I'm not sure if this will help or not.
It doesn't indicate if the felt is in the middle or to the outside where the cable attaches.
I think if it was anywhere, it would be to the outside to try and prevent oil from traveling up the speedometer cable. However there is this from CCOT’s speedo cable page that seems to indicate NOT using the felt on my style gear housing:
Yea mine was a .010 shim under the front output nut when I tore it apart, probably get burned on the cross for this but I left it off. Can't remember if it was supposed to go there or not. Someone will come along and straighten me out I'm sure lol.
Maybe it sets the front output bearing preload? The one in the nosecone isn't a conical bearing so I doubt it has any affect on that...
Interesting that yours was under the front output nut - maybe that's where mine came from too. I tried to take pictures during tear-down, but naturally, I took a picture of the shim, staked nut, and washer, but not where they came from!
