RTH: Speedometer Gear Housing
Delawhere?
Slee's speedo gear correction for 285s arrived on Friday, so here I am in the garage this weekend for a "simple" swap out.
Well, I'm up against corrosion.
I had to use a small chisel to get the hold down tab off. Channel lock pliers got the housing to rotate just a few degrees, but it's still frozen; and, the channel locks are really marring the perimeter of the housing.
I've already boogered up the threads some since, yes, a brass drift will dent up these soft threads. :bang:
Any suggestions for getting this bear out? I'm off to the store for PB Blaster.
-KK
This is an aluminum-on-aluminum deal that may be gaulded, I'm not sure what PB will get you. Once the tab is removed the sleeve should be able to be rotated 360 degrees. I would try to rotate it back and forth to see if you can break it free.
You can get a new sleeve if needed, try not to damage the transfer case housing.
Curtis and Dan, thanks for the responses.
WD-40 applied in the morning; WD-40 was all that I had on the shelf. PB Blaster applied in the afternoon after purchasing at Pep Boys.
Tried it again after a little time lapsed, and presto. Rotated as expected.
Seems that, even though the truck grew up in Texas, it doesn't take long for the corrosion to catch up around here.
-KK
