RTH small coolant leak from engine passenger side
Israel
Small coolant leak from an engine passenger side beaind the front exhaust manifold
I noticed this new red wetness under the rig
I was thinking where did I get a hydraulic fluid leak?? It took me time to understand it is T red coolant.
I looked under the spot and I saw a small trail of coolant.
Any ideas? I checked all hoses and everything is dry and secured I just finished a total cooling system overhaul I can't find a leak
Were this could come from?? Engine works like a charm ?
Looks like a pretty good coolant trail, maybe a good idea to follow it to where it starts? A cooling system pressure tester can be helpful.
You are so right
So I drove to my friend the farmer, he has a small corner with a car lift and all the tools in the world and OCD he worked on Isuzu and I worked on his nerves by not putting back to his according to his standards
While the engine cooled down we drank Arab coffee, smoked and I was crying like a baby that my engine is tosted
I removed the exhaust heat shield and pressurized the cooling system and could see sweating droplets from pin hole on the oil cooler cover
@brianh699 has a bingo congratulations and thank you
Oil cooler leak, this thread has some good info and pics
Coolant leak under exhaust manifold!
I am going to order all the necessary parts to overhaul the oil cooler
In the link above @450LX has a picture of the engine wall after removal of all the parts with a cap I marked I can find any data on this metal cap
Is this replaceable? Part number?
Yeah that's a freeze plug. You might be able to find one from a machine shop. Probably just need to measure it and order one from anywhere. I don't know how often they leak, if ever. You might want to just leave it alone if it's not leaking.
