This past snow storm, my rear locker wouldn't engage - the light on the dash just stayed flashing.
With the help of some older posts, I was able to remove & start trouble-shooting my rear locker actuator. It runs in & out nice & smooth, but it seems as though the actuator rod that connects the actuator assembly to the shift fork isn't in the correct position - it needs to move out one tooth or so.
When I retract the actuator rod all the way using the 9 volt battery method, and try to reinstall the assembly in the axle, the hole for the shift fork doesn't line up. Same goes for if I extend the actuator rod & try lining up the bolt that goes from the shift fork to the actuator rod (while the axle is locked, of course).
How do I realign the actuator rod with the shift fork hole? Do I need to take the actuator motor and spring assembly apart in order to adjust this, or can I just run the shaft out a little with the 9 volt & reinstall everything?
This is the thread that makes me think I can just 'adjust' the actuator rod position with the 9v: https://forum.ih8mud.com/80-series-tech/241132-locker-actuator-9-volt-test.html
But this image from the FSM makes me think I have to take everything apart to realign the gears or something:
Image refused to prevent confusion.
