97 LX450. Driving home and having an intermittent issue with the brakes.
Press the brake pedal, goes down about halfway like normal, and is firm, but the truck doesn't stop...even if I hold the pedal there. If I continue to force the pedal, it will slowly (eventually) continue to press to the floor, with a lot of resistance, but the truck still doesn't stop. 10 seconds later, the brakes may work fine, or I may experience the same issue.
Before I replace the entire brake system, I'm looking for answers.
Front brake pads are about 50%
Rear brake pads are about 70%
New rear rotors this summer
Two new calipers this summer.
New master cylinder two years ago
Everything is OEM Toyota
My initial thought is a failing brake booster. Open to suggestions. Have searched, but have not found an identical issue described. This is my wife's daily driver, so would like to get parts ordered and replaced as quickly as possible.
Cheers
Cheers
