RTH--Brakes completely failed
Baton Rouge
My brakes just completely went out and the pedal went to the floor. They did not return. No fluid loss in reservoir--I've been watching it.
air in the lines will not cause this dramatic a failure, right?
Is it master cylinder? Thanks.
Air will make them soft...but air does not just suddenly enter the system. This sounds more master than anything. Anyone been putting engine oil into your brake fluid?
to be clear, i have been having soft pedal problems, but it firms up after a quick pump. No pumping would bring them back this time.
From my FSM:
Low pedal or spongy pedal
4. Fluid leaks for brake system
5. Air in brake system
6. Piston seals: worn or damaged
7. Master cylinder: faulty
8. Booster push rod: out of adjustment
+1 MC
I have had an Honda mc fail in the same fashion. Almost no warning at all. I remember being able to slow the car down after pumping the brake pedal, enough to drive home.
The stealer wanted 300-some-bucks for the job. I did it myself for <$100 and thought the job was pretty easy.:banana:
If it were me, on the cruiser, I would contact CDAN for the new parts.
jt
x3 on MC
mine blew out a while back, symptoms were the same
repair is pretty easy
be careful w/ the fluid- it'll eat paint. *When* you spill, wipe up quickly w/ rag(s) then rinse... but don't get water into the brake lines nor the reservoir
Just throwing this out there that others have reported, after lots of headscratching and searching, that spongy pedal feel and brake issues ended up being due to the soft rubber lines...
The soft lines get old/worn and even though they may not leak, the can get to a point where they are not able to retain their shape anymore and so when you push on your brakes the fluid expands/blows up the soft lines creating pockets of fluid rather than pushing the caliper pistons. One person I know could actually see the hose expand when someone pushed on the brakes (this was on a 40).
Sounds like your problem may be more severe but if you were having problems with spongy brakes and had bled the system properly with no success this might be something to look into.
