Wilson Antenna Tech support - Fiberglass SWR Notes It is an impedance wire. From what I understand, I don't ground it unless I cant get my SWR below 2.0:11. What is that wire at the bottom?
Wilson's exclusive impedance matching transformer is connected through the external wire at the bottom of the FGT and Flex series of antennas. It is NOT a "ground wire" to increase the ground of the antenna, although using the lead does make the antenna DC ground. It is used when you are not able to get below a 2.0:1 SWR even after tuning. This generally indicates a mismatch of impedance between the coax and the antenna. This can be caused by poor ground but is generally attributed to the mounting location. It re-inserts 25 ohms impedance at the antenna feed point and brings the system back to the 50 ohms required. It is not a tunable device, therefore it is not fooling the radio into thinking the system is matched. It is actually matching the antenna and feed point to the required 50 ohms impedance for the coaxial cable. The most often time it will be used is when the antenna is mounted on the top of tool box in the bed of a pick-up, or on the passenger side of a tractor using co-phased antennas.
2. What if I do not need the impedance wire?
You have the choice of either cutting it off or taping it out of the way. In making your choice, consider if you may move the antenna to another vehicle, that installation might require the lead. For the most versatile use of the lead, simply lay it alongside the fiberglass and tape it in place. Using electrical tape will offer the easiest method and offer the best protection against weathering conditions.
