RTH - A/C compressor replacement
SoCal
Website
www.adventurebuddies.com
Hi folks. Thanks in advance for any help.
My a/c clutch died, so after reading all the helpful prior posts, I decided to replace it with a reman from RockAuto. But the pressure plate is frozen solid to the compressor shaft. No amount of pentrating oil or prying has enabled me to get it off of there. I even managed to puncture my radiator while fiddling with the darn pressure plate :bang: - but that's another story.
So now I'm considering replacing the compressor as well since I can't get the pressure plate off anyway and I'm worried that all the prying might have compromised the compressor bearing. I have now read the threads on compressor replacement, but I need a little help discerning exactly what parts I should buy. Here are my thoughts:
1) Drive truck to A/C shop and have them evac the system.
2) Drive home and replace parts. Compressor, clutch, and ??? I've read that I should replace the dryer as well. Any other parts while I'm in there? (BTW, the system doesn't really leak or anything)
3) Drive back to A/C shop and have them charge the system.
I also need some help choosing a compressor. I'm going with a reman for budget reasons. RockAuto has a Denso 10PA17C for $270 and an ACDELCO 88918980 for $300. Any opinions on these? Anyone know if they come with the oil already in them? The clutch I already purchased is the DENSO.
I know this is long, but I really appreciate any help now that this has turned into a bigger affair than intended.
Maybe too much loctite was used on the bolt.
Try gently tapping the plate inward then pull?
It is on a splined shaft and should not be hard to remove, you did remove the little bolt, right?
...after looking at the FSM, it calls for a SST to remove the plate. Looks like a small puller.
I have never had problem doing the handful I've worked on.
You also my want to contact Rex a.k.a.,1972FJ55, he's the very knowledgeable Air Conditioning Parts Manager at coolstreamac.com
Yes, I did remove the little bolt. It just won't budge at all. It does show a puller to get it off in the FSM, but that means evac of the system and removal of the compressor at which point I figure I might as well replace the compressor.
I went for a cheap new compressor for $189, cant remeber the place but can look it up. When mine came it said it was pre oiled, I did not trust the amount and drained and added per the manual PAG46 since the local toyota nd-8 was $56 for 4 ounces. The PAG46 was $7 for 8 ounces. I also went with the shorter drier from Dan and replaced every o ring along the way. I would also suggest you replace the shrader valves. That is of course if you have to swap the top plate like I did. Some suggested using toyota O rings but my local Toy parts guys were idiots and just brought out a box of them and said get the sizes you need. Some were $3 each so I took a chance on the green ones from the parts store that were $5 for 48 of assorted sizes.
Interesting. I didn't realize there is a shorter dryer. I'll look into that.
The 1" shorter drier is Denso #478-0500, MUD price $20.81. A new Denso compressor with clutch is $259.
Rex
That's great. Is that from Cdan?
