RT - No Start...possible starter?
Cedar Rapids, IA
1992 3FE 237k miles.
Went to leave work and my truck wouldn't start. No crank. Nothing. CEL comes on. Everything lights up right but nothing. Possibly related, possibly not, unsure, last night I got a little bit of belt whine on initial acceleration. When I let off the gas it went away. It did it twice but then stopped.
Things I've checked:
1) CEL came on. BUT after trying to start it 5-6 times it DID NOT come on. I checked the EFI fuse and it is not blown. Put the fuse back in and CEL came on.
2) Checked and wiggled the wires at the positive of the battery. No help. I don't have a "normal" fusible link because the stereo installer butchered it 11-12 years ago. I have an 80 amp inline fuse instead.
3) Battery shows less than "half way" when I turn the key on. Normally it is higher than this. I'm wondering if the lack of battery has anything to do with this and is related to the belt whine last night. But I don't get any attempt to try to crank like when you have a low battery. Could the belt be loose and not be cranking the alternator enough and that caused the problem? I saw no indications of dying battery this morning when driving to work.
4) Checked the shifter and made sure it was in park all the way. Also tried starting in N.
Thanks for the help...
Paging Mr. @jonheld. I'm kindly requesting your assistance.
at least you know it ISN'T the Head Gasket and it isn't related to the super charger...
Have you checked the actual voltage at the battery?
Also, have you checked/swapped the EFI relay?
Who am I kidding, I'm just killing time until @jonheld can save the day...
I'm on my way back now. Went home to get my tools. I relocated my EFI relay 6 months ago and haven't had any issues since.
Fortunately it is sitting about 100 feet from AutoZone as I work at Lowe's and have to park at the end of the parking lot. I'll know more in 10-15 minutes.
Intermittent belt whine could be associated with the alternator trying to charge battery with somewhat loose belts. Check voltage as Golgo mentioned on battery posts. Sounds like you need a battery or a jump.
That's what I am wondering as well. Going to check voltage.
Just hopped in and flicked the key. Fired up. She started a little rough and is idling a little high. Presumably because of pulling the EFI fuse.
Battery is half way between the middle line and high line where it normally is. Haven't even checked the voltage or anything yet.
WTF?!?!
I would definitely check the alternator belts for tightness. If loose, they whine at first then they could start slipping and not charge the battery.
Top belt is definitely loose. Checked my maintenance notebook and it has been 45k and about 5 years since I replaced it. Going to tighten when I get home and order new tomorrow.
Also had AutoZone check the battery and alternator. Both checked out "good". My Optima Red Top is 3 years old. I get free batteries from Interstate which is why I have an Optima. Need to replace my battery cables though. Positive one is having a hard time clamping tight tight. It's snug and doesn't move but it's worn out.
Keep in mind that the EFI circuit, ECU, and just about every other system in the truck has NOTHING to do with cranking the starter.
Battery, fusible link, ignition switch, neutral start switch, starter solenoid is the logic path. Load side is a direct connection to the battery. The fact that your voltage is reading low is shouting to me that you have a power source issue.
Yes. 99.9% positive it is the fusible link abortion that the stereo installer did 11-12 years ago. Got it to replicate at home in the garage. A bad crimp. A little wiggle and it would work. A little wiggle and it wouldn't work. Also need to get around to replacing the battery cables...
