RT HELP ---FUEL PUMP NOT GETTING POWER
Pensacola, Fl.
I have checked fuses, relays associated with the fuel system all seem to be good... the ONLY way i get power to the pump is when I jump the diagnostic port with a paper clip, then I hear the pump come on...
Is the CEL coming on when you turn the key to IGN? If not, check the EFI fuse and the fusible links. Use a voltmeter for the fusible links, not just visual.
Fuel pump doesn't run if engine isn't cranking/running...
What's your actual symptoms/problem? Crank and no start? etc etc?
And yeah, answer Ali's question too.
cheers,
george.
thanks for the reply...
Not sure i dont have a OBD 1 scanner.(NEED TO GET ONE) I checked everything i inspected with a voltmeter... The only fusable link i know of is near the battery, is there more?
"Seem" is not good enough.
Ali asked a question. Do you get a CEL when you try to start the truck? Until this is answered we are just guessing.
This is a step by step process to identifying the source of your problem.
The CEL is the little engine light on the dash. It should come on when you try to start your truck. Does it?
Don't need an OBD 1 scanner. Try to start your truck. Does the light that looks like an engine come on at the bottom of your dash?
No. It looks like a little engine at the bottom of the dash.
It is orange.
THE STARTER IS OUT RIGHT NOW, IT WAS ACTING UP PERIODICALLY... WHEN I TURN THE KEY TO ON ALL THE ICONS LIGHT UP AND DONT GO OUT... INCLUDING THE ENGINE
Obd 1... So i assume u have a vafm and not a maf sensor? If the efi fuse, and cor are ok, then i would suspect vafm/maf. Fuel pump wont kick on till the vafm or maf detect vacuum.
Rebuilt what? The '94 or '96 ? '96 is obd2.
Not to poke at you, but spins over, stops spinning, never tried to crank.... wtf??
When we say crank we mean the engine is cranking due to the starter motor. It is what happens before the engine starts and runs on fuel...
We need to get some nomenclature established here to understand what you are doing AND to what engine.
cheers,
george.
I actually rebuilt a 95 motor put it in my 94' removed the PAIR and EGR. installed new harness...just got it all back together. All that is left is to mount the ECM and couple of other electronics that go behind the glove box(CANT REMEMBER WHERE THEY MOUNTED) AND CANT FIND A PIC ANYWHERE....
95 is OBD II.
What wiring harness did you use? What ECU are you using?
So, finally the truth comes out (please look at your first post and wonder how any of us could provide you any useful hints)... From that first post the assumption is that you had a running vehicle and it just stopped pumping fuel... versus a rebuild/rewire/mish-mash...
Given we have no idea (certainly I have no idea) what state anything is in. You haven't mounted the ECM? How will the fuel pump activate given the signal comes from the ECM?? Or is the ECM just 'dangling' on the harness?
Yeah, you have a few other issues to work through... :)
cheers,
george.
EVERYTHING IS OBD 1 LIKE I POSTED EARLIER... HARNESS, ECM ALL 94' THE ONLY THING FROM 95' IS THE MOTOR BLOCK.. THE ECM IS MOUNTED...
ANYBODY WANT TO TAKE A PIC BEHIND THE GLOVE BOX FOR A BROTHER, SO I CAN MOUNT THE TWO MYSTERY ELECTRONICS??
NONE OF WHAT YOU MENTIONED MATTERS... THE FUEL PUMP IS STILL NOT GETTING POWER...
IF YOU HAVE SOMETHING USEFUL TO CONTRIBUTE FEEL FREE IF NOT BUG OFF...
