Hi everyone, I wanted to ask for everyone’s thoughts on an issue I’m facing:
Timeline
The issue
The following issue only started occurring after my above mentioned visit to the shop. Keep in mind the car drove fine for 2k miles before the visit.
This results in RPMs spiking/fluctuating harshly between 600-800 (see video). VIDEO:
It doesn’t necessarily affect driving performance (as the RPM fluctuation does not occur when driving, only when idling). Also, no codes are returned.
I am a complete noob when it comes to this stuff, but I started with resetting the ECU, and soon plan to inspect and test all spark plugs and ignition coils. However I’m not sure what direction to go if this does not yield results. I’d greatly appreciate your thoughts on the matter!
Timeline
- at 154k miles, replaced motor (due to overheating via failed coolant lines) with a used 145k mile motor (done by Mudrak)
- With new motor, I had driven approx 2k miles with zero issues
- Then I had a string of misfire issue codes being returned. After trying to swap coils myself and codes still returning, I brought it back to the shop and Gary replaced a number of spark plugs and coils. However, we did not check every coil and spark plug. The misfires were fixed and no codes are returned.
The issue
- Vehicle in Reverse or Drive
- Foot on brake
- A/C on
- It also seems to be exacerbated in higher temperatures
