Rough idle
Australia
Hi guys, it was suggested I post in here instead of the 100series section as the 1FZFE wasn’t in the US 100series, not sure if anyone can give us some ideas we haven’t already checked but here goes. We have a 99 model 105 series cruiser with the 1FZFE engine on auto gear box standard with no mods or turbos. Has just ticked over the 300000 mark.
Currently running rough at idle and worse on acceleration. ?? Missing cylinder no 5.
What we have done so far
Compression test perfect
Valve clearances fine
Replaced vacuum li es
New Inlet manifold gaskets
New spark plugs and leads
New Injectors
New coil packs
New cam and crank angle sensors
Had computer connected and now error codes or faults show
New fuel filter and cleaned and checked pumps and tanks
New fuel pressure regulator
we are really at wits end and just want it back purring like it always has any other ideas even simple that we may have missed?
Desperate mum
US spec 80 series with the 1FZ-FE motor have a well documented problem where the main engine wiring harness gets damaged where is passes the EGR valve. The harness support at the firewall fails and the harness touches the EGR tubing. The harness needs to be opened up in that region and repair damaged wires. If you search the forum you will find numerous threads with many pictures detailing the specifics. A second problem area is where the wiring harness gets damaged, near the connection to the ECM, where the harness gets damaged by rubbing against the metal supports.
Did you clean the Throttle Body? Its tricky- sometimes cleaning that gunk makes the butterfly work better and idle smoother. However, if the butterfly and surrounding area has been dirty for a long time, it could have been making it seal and when you remove the gunk it negatively affects the seal. If you're fishing for stuff to check thats pretty easy to and made a (positive) difference on my vehicle. Its a judgement call.
Thanks I will have a closer look in australia we don’t t have the EGR on the motors but I assume the loom would still be there
Checked/adjusted the throttle cable? Is there too much slack?
Will look again but that all seemed tight and was at idle and worse on acceleration
Check the wiring to the #5 fuel injector, I know getting rough with those wires can cause a break. What plugs do you have in it? I know these trucks like the original copper plugs. Getting those fancy plugs can cause issues. Check your timing too or maybe the newer motors don't have a distributor? I forget.
Do you have a mass air meter? Maybe swap with a known good one and see too.
No distributor 🥺 just standard plugs and replaced them just in case will look at the wires again just in case
Will double check but I think this was checked
I know you have done a ton to diagnose your rough idling issues, but have you cleaned or replaced your air filter? Is your check engine light on (thinking dirty O2 sensor)?
I don't know if you saw the thread: 1993 Fj80 Rough Idle, runs great other than that
He didn't get resolution of his problem, but there are some nice suggestions about the EGR and IAC. Let us know if you do figure it out!
I will definitely let everyone know if we solve it. In Australia we dont have the EGR but yes is does have a new air filter and have run it with the air box open to check for blockages i. The snorkel as well.
