- Joined
- Mar 13, 2014
- Threads
- 18
- Messages
- 50
I need help with this, I have a 1993 FJ80, that I have replaced almost everything, the last problem was the throttle cable was sticking so the RPM would always be around 1000-1200 when in park or neutral unless you pull back on the accelerator with your foot, so I replaced the throttle cable, readjusted the TPS to spec by the FSM using feeler gauges and a ohm meter, I replaced the cap, rotor, plugs, wires, every vacuum line, including all under the intake manifold, rubber intake hose, the evap canister, fuel filter, both 02 sensors, fuel pressure regulator, TPS, cleaned and inspected all the injectors, cleaned the throttle body, the IAC, every hose I can find, I replace, disabled the egr, it runs great and pulls strong without vibration at anything other than idle now after replacing the cable, when you come to a stop, it slowly falls from 1000 to around 550 where it idles rough and vibrates really bad, as soon as you blip the throttle in park or drive it stops and runs great, until you come to a stop, when it's cold it revs to about 1800 for a minute or so then falls to idle. it runs great when that happens, any ideas where to go with this? I disconnected the battery after i adjusted the TPS thinking it needed to relearn the idle because the cable was sticking and it was fighting that, but that didn't seem to change anything.
