Rough idle questions
  • Thread starter Thread starter skunkworks
  • Start date Start date
S
skunkworks
Guest
I've been experiencing rough idling after startup and while driving at sppeds below 35 mph. It runs smooth when at full throttle or on the highway. The plugs, wires and cap were replaced within the last year as well as the throttle boby gasket. I pulled a code 26 and in mentioned the air/fuel ratio. Could it be a defective MAF? What else could be cauing this problem. It seem to have gotten worse in the cold weather (I'm in toronto).
Thoughts :confused:
have you checked your air intake tube? it could be cracked. the air intake tube is the large one that runs from the air cleaner to the MAF.
you won't know by looking at it, necessarily since the crack(s) could be on the bottom of the tube.
mine was cracked underneath.
if it is cracked, you can buy some time before replacing it by wrapping a bunch of tape around it, but I'd replace it ASAP, if it is damaged.
Doug,
Would that account for an intermitten surging up & down at idle also? As soon as mine's in gear, it doesn't surge.
Sorry for the slight hijack.
I checked the tube it is fine. I cleared the codes and got another code 26. I'll get an intake smoke test done. ...Maybe I have a vacumm leak. Anything else it could be?
Doug,
not sure about the surging up and down.
I don't know much about the 3FEs...assuming you're talking about your 91
what year is your 80?
Rig is a 1994. Its in great condition and I have hardly driven it since late last year. I brought it in to Toyota and the they pulled a code 21.
Last year I replaced both O2 sensors after pulling a code 26. It went away and a couple of weeks later I pulled a 26 again. I have new plugs,wires, rotor and cap. The intake tube is not cracked.
The dealer says I have heated 02 sensors and that one sensor is showing steady voltage and the other is erratic. They recommend replacing the sensors again which does not make sense to me unless I fouled them from driving rich (is this possible). They also mentioned possible ecu replacement or a wiring issue? Shouldn't the dealer be able to tell me which of the two o2 sensors is reading erratic...they claim not to be able to do so. I thought the dealer diagnostic was better than the standard garage readers? I feel I wasted $160.00.
Its really frustrating because the rig is very clean and runs nice excepting this hesitation. my garagist recommends that i swap ecu's and if that does not work they will check the wiring. What else could this be
-wiring
-bad injector
-fuel pump
-maf
???....anyone have a spare euc i can borrow lol
Check the 02 sensor wires for cracks/shorts and 02 electrical plugs for water/corrosion.
Recheck cap/rotor for wear and plug wires for chaffing, spark plugs for fouling.
