Rough idle at stop
37° 52' 18" N / 122° 16' 18" W
Greetings,
Earlier this month my '92 would not hold an idle after start.
Turned out the air flow tube was cracked.
After replacement with dealer tube, idle after start, in park and in neutral is smooth (750 RPM).
However, while stopped in drive or reverse the idle is rough and quite shaky (650 rpm) .
Recent: new air cleaner, new plugs, new air flow tube.
This weekend's trip to Tahoe (0 to 8000 feet) and back had best gas mileage since I owned it, 11.36 mpg compared to less than 10. Not great improvement....but an improvement.
What say you?
Cheers!
You idle speed is exactly where it should be.
Rough idle is almost always associated with vacuum leaks or unmetered air entering the system. If the intake tube was replaced, make sure all clamps are tight. If it's getting rough under load, then as the engine shifts in the mounts, something is opening up allowing air to enter. Look for the easy stuff.
You put in new plugs. How about new (OEM) plug wires, cap and rotor? That can get rid of a lot of loaded misfires. Also, if your intake tube was cracked, odds are you have other vacuum hoses that are old and cracked. Replace them to get clean vacuum.
