ROTW - TX_TLC
where did you get the supplies for your roof rack fix and do you have part numbers?? Thanks
I got these at autozone...they can be aquired from any auto parts store...
The plugs aka auto fasheners are Body-Tite! #45680 Chrysler/Ford/GM and the silicone is DAP Gaskets 100% Black Silicone.
During removal of the roof rack I also removed the nutserts. Most popped out through the hole in the roof skin with very little effort.
Do those PIAMM horns make a noticeably louder bark than the wimpy OEM horns?
I'm shopping horn replacement and want some power .
Alboyce
1994 80
Stock, Locked
Alboyce
1994 80
Stock, Locked
It's not PIAMM, it's FIAMM. And yes, they are a different tone, which I think is much better than the OEM tone. The horn sounds louder, but I don't have any way to check decibels, so it's just sort of by ear.
Well worth the $10 each per horn. I bought a high tone and a low tone. I don't know what TX_TLC has.
:whoops: Doug is correct...they are FIAMM. IMO they are 100% impovment over the stock horns. I purchased both the low tone and high tone and they simply plug right in! The ground is the bracket/bolt.
I doubt you will be disappointed with this quick upgrade. I have heard that the Hella horns still have a high pitched euro sound, which these do not at all. They sound like a 100% American horn.
Funny the only part of any US truck I have had that I perfer over the horn of my Toyota...the horn. :D
reffug said:
I want one of den der horns dat'll play dixie..................................... :flipoff2:
The Sparky-wireless special? yeah...you'd dig it the most :flipoff2:
Couple more action shots...
nice...
Hey TX_TLC,
A tuff truck...very impressive PM list.
I like the roof rack fix...may I steal your idea?
How did you remove your nutserts...just yank 'em out with channel-locks, or something???
Andy
__________________
'88 FJ62, '96 FZJ80
AndyR said:
Hey TX_TLC,
Andy
__________________
'88 FJ62, '96 FZJ80
Thanks...
Of course you can steal the idea. It was one of many discussed on here.
To remove the nutserts I inserted a bolt 3-4 turns then took hold with vise grips and most quickly popped out. Only a couple did I have to really work on to pop them through. I found a circular motion worked best for the ones that provided resistance.
Then using the dremel, cleaned up the surface rust and then plugged the holes, sealing with silicone.
