ROTW ROTW: 73 FJ40 (color of money)
Member Rig of the Week
after i got the mounts installed for the final time, i buttoned up a few loose ends and then it was time for the first road test. everything felt great, no funny noises and no leaks right after i parked it.
it's alive!!!! :bounce:
when i got to the shop this morning, i looked under the rig first thing and there was'nt a drop of anything. i had cleaned the floor on friday evening before i left......and we had been dealing with a persistant leak prior to the orion repair so i wanted to make damn sure that there were no leaks after i was done with it. so no oil puddle(s) on the ground was a big relief.
after i got set up i got on the creeper to get a closer look at everything i had just worked on. to my dismay i found a leak. :frown: the front output on the nosecone was leaking, seemed like it was the seal itself. that was a little upsetting because i installed a new oem toyota seal and piloshed the seal surface on the drive flange prior to installation as well as applying sealant on the splines of the front output shaft.
so i decided to pull the belly pan along with the front driveline ( at the t-c end ). i opted to remove the belly pan because i was'nt super happy with the amount of flex in the twin-stick mount. you have to apply quite a bit of force to get the twin sticks to shift, especially the high-low lever when you're suing them with the updated detent for the high-low fork. so it takes a sturdy bracket. AA does not sell a braket for this application ( the C4 automatic adapter 0 so i had fabbed up my own. turns out it was'nt quite strong enough and allowed for some flex. so out came the bracket for some serious beefing up.
now it's built like the preverbial "brick s*** house" and there's no more flex thanks to greenfox who had the day off work and came down to the shop to help out as he often does. thanks again bro! :cheers:
once we were done with the shifter bracket we turned our attention to the front tc leak. upon removing the front driveline and yoke we discovered that the leak was between the nose cone and the seal itself, not from the splines or from the seal surface on the yoke. so it's not exactly something you could prevent or forsee. since i had installed an oem toyota seal and it leaked i opted for the marlin HD seal this time around. got it installed and everything bolted back together but i ran out of time so no test drives tonight. tomorrow moring i'll take the rig for a spin. then it'll be time to check for leaks again and move onto other projects i still need to complete like installin a ps cooler.......
here's one more pic for ya ross!
while i was waiting on the parts for the orion, don aka FCFabrication replaced the old seat mounts with one of his custom units. stronger, less bulky and the seats are now mounted a little lower like we'd hoped for:
i am so glad i found a link to this....
but now i have to go change pants
btw where was the photo taken of the girls snowboarding? i havnt been out on my board in probably 4 years.... that was all the motivation i needed to make sure to take a trip this season
I don't recall but one of the mountains in the Sierras...
Georg
I talked with you yesterday about this rig (The Color Of Money) I'm looking for pics of the T-case/tranny crossmember and am having trouble finding any. Help?
bringing this thread back from hibernation.........
ross brought the cruiser back down to the shop for a few more "upgrades". don aka fcfabrication buil;t some custom rear corner protection since it this was the only unprotected part of the body. since the cruiser does the rubicon trail a few times a year, it sees some dents in those areas. well, no more. i'll post some pics of them tomorrow.
we also opted to convert the rig to fuel injection. ross lives pretty much at sea level but takes the cruiser to rubicon and other trails at 7000 foot elevations or more. altitude compensation definetly becomes an issue with carbs and the last thing you want to do is to have to adjust the carb everytime you head up in the hills. nevermind flooding out the engine on the steeper or off camber obstacles.
we finally decided to go with the turbo city setup. it utilizes a gm throttle body along with a series of sensors, custom harness and a re-programmed computer all supplied by them. the kit we purchased was very complete. the only thing we opted for was to go with a gm style distributor. the installation went very smoothly, got both tanks plumbed for return lines, installed the frame mounted electric pump, the computer went in the glove-box, towards the top and we mounted a small 12v electric fan in the oem speaker hole to keep it cool. after checking all the new circuits and fuel pressure, we cranked over the engine and it fired up within 2 seconds. STOKED!!!
at the same time, we opted for dual batteries as well as a trick battery management system from extremeaire. a lot of the wiring in this rig needed to be cleaned up. numerous people had worked on it and installed the different harnesses or added to them so it was a mess. i tried to weed out the wires as best i could and re-loomed most of the engine compartment once i had all the new wires run where i wanted them.
another upgrade this time around is the extremeaire magnum compressor. until now, the 40 had a york for oba and a small arb compressor for the lockers. i removed them both and replaced them with the single large electric unit. this also allowed us to clean up the ps pump mount and pulley system.
last but not least, we decided to run an edelbrock aluminum waterpump. the engine in this cruiser had chronic heat issues. we had taken all the steps one usually would in trying to keep an engine in a 40 cool; aluminum rad, aux trans cooler, free-flowing exhaust, ......yet it was still running warm. the waterpump had been installed by the initial engine builder so we had'nt considered it possibly being an issue. upon removal we found out that the pump was a reverse rotation unit, designed to be run with a serpentine belt. got the proper pump on there now and so far, so good. we also installed a 195 thermostat while we were at it; the efi systems require a little more temperature to go into closed loop running mode.
here are a couple of pics. ross will be picking up the 40 tomorrow and i'm sure he'll post up more ( bikini chicks?! )
georg @ valley hybrids
Makes me want my build over
So I can get to the beach...we have some of the best fwd spots in the world here..if you like beach's and mountains and amazing scenery:cheers: . BTW superb workmanship...a shame sometimes that most people never know what goes into a truck like this.....Lee:p
