rotor removal question
Golden Colorado
I have a 73 FJ 40 and Im trying to look at the brake pads to check them on the front. The haynes manual says there is a screw you undo to get the rotor off. I do not have any screws just lug bolts to bolt the tire on. There is no bolts it looks like the rotor just slides on, How does this come off???
A '73 FJ40 would have drum brakes at all corners unless upgraded to disks. Do you still have drum brakes? If so, you have drums and shoes, not rotors and pads. If the front has been converted to disks, do you know what type? A pic would help.
Cheers, Blake
When you say rotor, I assume you actually mean 'drum'. The manual is (sorta) correct in that, from the factory, there was a screw that you had to remove in order to get the drum off. The screw really doesn't serve any purpose, so I'm sure it was removed and discarded a LONG time ago. I've never actually seen a drum that still had the retainer screw installed.
You should be able to just pull the drum off. Often, liberal application of a hammer is necessary to break loose the corrosion and gunk between the flange and the hole in the drum. You may also have to adjust the shoes inward in order to get the drum past them. Shoe adjustment is a whole 'nother topic...
I've got screws in mine
I have two; one with screws, and one where they have been tossed out.
To get the drums off, get a BFH and hit the drum towards the hub, like you're trying to pound it on. It seems disintuitive, but it works. Hit it between the studs. Go easy hitting it further out, or you might warp it. It will come off. Eventually.
