Rotating Engine on Stand (1 Viewer)
Coolerman
Paint Lick, KY
Website
www.globalsoftware-inc.com
Now this may sound a bit weird but seeing as how a Cruiser engine is top heavy when mounted on an engine stand, is there a safe way to rotate it so the oil pan is up? Seems an iffy proposition to rotate a 600 lb engine anyway. I was not able to even budge it.
I thought of hooking the engine hoist back up to take the weight off as I started the rotation.
Thoughts?
35inchoverdrive
Forge Specialties
VA
Website
www.facebook.com
I just had a couple of friends help me rotate mine...as if we could have stopped it if it started to fall... Anyway, it was on a 750lbs stand, which is scary enough, but it turned over without any real stability issues.
edit: I did have the head off when I rotated it.
Frankfort Ky
Website
www.threeelementsdesigns.com
I'll be trying this later today myself, but on a 1000 pound stand. If it falls and #@$%'s up my new motor, you'll hear the curses all the way from frankfort!
spotcruiser
Geezer
Western WA
As stated, you can use an engine hoist to take weight off the front. Also, it helps to use a longer bar for turning the engine over. A 1' bar just doesn't provide enough leverage.
McCall, ID
I just did it on my own, you weenies. No biggie.
Frankfort Ky
Website
just finished turning the motor over. My brother and I supported a little weight, and my girlfriend actually spun the motor. It was much easier than I thought it would be.
