Roof Rack
hguerrero said:
The roof rack on my 93 is starting to look its age...
Any ideas or tips on how to restore it? Paint it?
Henry
To make mine look better I removed it...and folded it up and threw it away. It has NEVER looked so good! :D...
If you havn't check for rust under the feet I would. There is a lot of information in the archives about this.."rust prevention mod."
IIRC the US wouldn't let them import the 80 with a roof rack so they were all port installed. Which brings up pictures in my head of hundreds of 80's sitting side by side as far as you can see. Then I see "them" giving a drill and $2.00 worth of screws and nutserts to a 18 year old kid and telling him to go drill 8 holes in the roof of all of these $45,XXX brand new rigs..:eek:
Ok so it might not be quite that bad...:D
To restore mine (after checking for rust and getting rubber gaskets) I just used acetone to clean up the rails (both the aluminum and plastic ends) and then painted with some cheap black spray paint from wally world. I think I used 1 can and it was 94 cents for gloss black. I also sprayed the rear deflector too. About 2 coats each. This was off of the truck of course. Looks shiney and fairly new to me now.
hguerrero said:
...suprisingly no signs of rust...
Did you remove all 4 pads? Were they worn down to metal or just to the primer? No rust inside the nutserts?
-B-
You can also peek between the headliner and roof by removing the molding on the sunroof and shine a flashlight to see the rust on the underside of the nutserts. The rust is there.
