2 of the 4 corner lock downs have broken off recently and I also nearly ripped the main arm on the driver side off. I guess I'm strapping down too tightly.
Anyway, I want to take the OE off and put something on with more meat.
Any suggestions? I like the new FJ rack but have not measured for fit and can't go Safari basket since it woun't fit in the garage.
Also, can the new rack be welded to the top or am I locked in to using the existing screw mounts?
Thanks!
Thanks!
and using the existing holes doesn't really gain you anything structure wise etc. As mentioned most go with the gutter mount system. If you are really serious about getting rid of the OEM rack then you can do what others have and remove the rack, weld up the holes, apply paint and done.
