Roof Rack Lights
I took piece of 4 wire romex and went down the frame behind the rear bumper an came up the side of my tail gate and lift hatch. Then took a zip tie to the back roof rack clamp. There is a little romex showing but it beats a hole in the roof.
I like the romex. Its a good gauge wire for a long run plus its in its our wrap, and color coded on the inside. I have 6 lites on the front (3 switches 2 lites on each one) and 1 work lite on the back of the rack. They ground through the rack to the body.
I have never had any problems.
Man up, drill through the roof, add a disconnect and here are all your connectors and pass thru's:
http://www.heyco.com/
:D
Of course I haven't man'd up myself but I'm getting there. :flopoff2:
If you pull the headliner down a little you can poke up through the holes used for the stock rack. Or if you're leaving the stock rack on, take it off then drill where the feet will cover it. Drill another hole in the side of the stock rack foot, then the wire goes up and through it..
UGA LEE- How long have you been using the romex? I would of used the underground rated romex instead if thats what you want to use. The romex isnt rated for outdoor use and will crack to pieces and turn a ugly yellow over time.
I used the under ground stuff. It has been about a year and a half and the outer coat is still soft. It all ready had a yellow coat. The picture aint that clear cuz the flash.
