have some questions for you guys about a 6.2 swap into an 86 fj60, i was refered to you guys from the SC upstate forum.
are the sbc (post 85) adapters the same bolt patern as the 6.2 diesel? (i'm assuming the adapter kit hooks the LC clutch/pp up to the diesel flywheel)
will the sbc motor mounts/engine mount brackets be the same as the SBC (can i remove enigine mount brackets of of a chevy pick up with a SBC and weld them into my LC?)
last but not least, my p/s, alt, and a/c, can i adapt those to bolt to the 6.2 or will i have to adapt my LC to use the chevy accessory componets (i have to keep a/c)
I will be running this engine on stock tires, stock suspension and stock 4 speed. eventually i will upgrade to an H55 and upsrade the suspension but much later on down the road. (i have new shocks to install but have yet to do so)
thanks guys
thanks guys
