FWIW, I just rebuilt a 1fz that had two bad rod bearings, and it did NOT knock under load. At idle and under load, it was completely quiet. Only at start up (before oil pressure built up) and in that area between acceleration and deceleration did it make noise. Therefore, if you have a knock under load, my guess is that you probably have something else going on.Changed the oil added lucas and still knocking badly . When i put the engine in at a load it is a very distinctive knock
Question for you.FWIW, I just rebuilt a 1fz that had two bad rod bearings, and it did NOT knock under load. At idle and under load, it was completely quiet. Only at start up (before oil pressure built up) and in that area between acceleration and deceleration did it make noise. Therefore, if you have a knock under load, my guess is that you probably have something else going on.
Oh yeah! When I'd crank it, and before the oil pressure built up, that's when the sound was at its worst.......it'd sound like the engine was about to come apart. Then, within no more than two seconds, everything was quiet......But keep in mind that, due to the increased clearances between the rods and the crank journals, the sound happened EVERY time the truck was cranked. In your situation, it sounds (to me) like you've got something other than a rod bearing problem.Question for you.
Was the knock every time you started. I had twice what sounded liek rod knock. Both times truck was on level ground. That only happened right after the start up and went away after that. However, All starts when truck was parked at the house on incline and decline did not got knock![]()
I will start tearing things apart on weekend (it supposed to be cold so Iwill not enjoy this)Oh yeah! When I'd crank it, and before the oil pressure built up, that's when the sound was at its worst.......it'd sound like the engine was about to come apart. Then, within no more than two seconds, everything was quiet......But keep in mind that, due to the increased clearances between the rods and the crank journals, the sound happened EVERY time the truck was cranked. In your situation, it sounds (to me) like you've got something other than a rod bearing problem.
This may be a stretch, but I've seen it on other cars: make sure all of your torque converter bolts are tight on the flex plate (flywheel). Years ago when I worked at a Ferrari dealership, we also serviced Jaguars. For some reason, the Jags of that era were bad about having the torque converter bolts get loose, and you can't believe the noise it would make........sounded JUST like bad rod bearings..........not knowing any more about your problem, that's just a guess, but it would be the first place I would look.
Hope you figure it out
Sorry I brought thread back since dnp appear to had knock on the startup just like me. As it turns out he always had it I just have only in one specific time (atleast for now)I'm confused by the hi-jacking of this thread who is asking what and which truck??
