Rocker panel plugs?
Indiana
To seal or not to seal? I noticed most the rocker panels have plugs except the two closest to the front. Should I leave those out so water can escape or plug them?
Although the rockers have small drain holes built into the seam, I leave the forward and rear most plugs out. If you plan to wheel in a lot of mud, you may want to plug them and make sure the small drains are open.
I think the answer has a lot to do with where you live and how your rig will be used.
In my opinion, leaving the two ends open and flushing the rockers out occasionally is best. This will assure that no water ever stands inside the rocker.
Thats kind of what I thought too. I didn't want to trap water in there. Thanks again Baldi. Battle Ground, IN??
