Rock lights - drill less mounts
Tulsa, OK
So, I've had some rock lights (tractor lights, utility lights, you know the flutted lens wide angle ones) sitting around for way too long. Finally got some time to mount and wire them. How to mount was the biggest issue. The fully boxed frame is great on 80's but it makes putting a nut on the back side of anything kinda tough. So, I used a trick I picked up somewhere or another. There are a couple of square holes in the frame right about where I wanted the lights. So, I cut a couple pieces of steel, drilled a couple holes, welded on the nuts, and used these little plates to go sit on the back side of the square hole in the frame - the pictures probably explain better than my words. 8 lights in all, think that's too many? ;) 2 in back, 2 on each side, and two in front pointing out and down.
last one - I didn't get a shot of the front ones and it's dark...
edit: duh, if it's dark out I can get shots of the lights on - one of the PS side lights has a bad bulb I think - need to investigate, but it's cold, dark, and my hands hurt (waaaaa waaaa waaaa)
Awesome idea on the frame slots. Do you have any pics of the front pair? You might want to consider the bracket that's available to retrofit a Tundra alternator with all those lights. :D
I would recommend the ground fastened to the bottom of the frame be relocated though. You'd hate to be night wheeling up at Disney and lose your lights to an errant rock.
Looking good. It's dark out now....time for night time pics.
last ones -
Passenger side battery box aught to be here tomorrow for dual bat. set-up. I've seriously considered putting a one wire GM alternator on IN ADDITION TO the stock alternator - run the second battery completely seperate from the first. Nuth'n like redundancy to make you feel safe right?
more info. on the tundra alternator please?
Ten times better than neon. Love it. Nice job. Two Alternator's would be real nice.... real nice.
