Road Trip checlist
Denver, CO
So I wanted to post a thread that could potentially help others that are planning a trip in an 80 series...
My wife and I are planning a trip from Denver up to Paradise Valley, MT to see family for the 4th of July. We plan on making it a 'mini' overland trip with some camping and exploration on the way there and back. I've yet to plan out the trip, but that'll come soon enough.
I purchased my 80 series about 2 months ago. It's in great condition and is basically set up for a trek like this with exception of a winch and some other recovery gear I'll need to purchase. 220xxx miles on the clock, but it runs amazingly well.
My goal is to get some opinions in sections.
1st, a general list of maintenance items to have completed before heading out as well as parts I may want to have on hand. I have a small pile of reciepts from the previous owner (PS front axle work, new radiator, wheels and tires, new cats and exhaust, info on the lift and components, etc...), but am unsure of those little "80's series" things that could cause a potential issue on the trip.
2nd, from those experienced, a list of the minimal personal safety and camping items you might bring along. Living in Colorado my whole life, I've compiled quite a pile of camping stuff, but you know how it goes. I could always use more. We'll mostly be sleeping in the truck. I've made a drawer system the right height to utilize a blow up mattress for sleeping inside.
3rd, any resource you might be familiar with in aiding the planning portion of the trip. A website or program, perhaps, that details off the beaten path roads and campsites alike. I'm open to all suggestions here and have done plenty of research thus far, but would like some input. Everyone knows something I don't!
Anyway, I hope this thread isn't repetitive and I appreciate any advice you may have for us!
Cheers!
I am very interested in this as well. I am planning on a cross contry road trip from VA to cali and back. this would be a first for me and would like to get as much info and prepare much as possible.
I got about 210k on the odo and I'm really contemplating about doing the head gasket as pm. Did you get your head gasket done? Any opinions on whether head gasket is necessary?
Thanks
Some of the better articles I've read with regard to overlanding/expo/modding can be found on expeditionportal. One that might be of use is called the "10 commandments". It's basically a need vs. want deduction that emphasizes a somewhat minimalist perspective that highlights what is necessity vs. semi-useless bling. It's not an exhaustive list, but one that helps me keep perspective when I have the urge to strap 12 jerry cans to my roof rack "just in case". Basic PM is aplenty right here on MUD! :)
I do love these getting prepped lists I must say. I am a 'backup for backup sake' person which TBH is a PITA. To 'control' this a little I spend plenty of time checking out the 'planned' route before looking at the 'you might need this' list. If you personally think you are going to be 400+ miles from the nearest petrol station then yes check out a couple of jerry cans. If the route indicates 50 miles from the nearest water then yes take a load of extra water. The Expedition Portal is excellent advice and I have checked in there quite often. If the route is serious miles from the nearest garage or spares shop then spend some time getting the PM right and the 'might fail' list up to date. So start with your route and THEN work out what may be needed on the way. For me the problem is the relative rarity of the LC in Spain so spares can be difficult to obtain quickly. TBH I have got better of late, a spare set of keys/passport oh and a credit card!!. :D
regards
Dave
Thanks
I don't have record of my head gasket being replaced anytime recently and it's definitely something I'm considering. Luckily I'm a mechanic by trade and have the space and tools to do it, albeit, I've heard it's not too difficult. Easiest way to check if it "needs" it (or any vehicle) is to look at the interference between the block and head and make sure there are no leaks.
regards
Dave
Great advice! I appreciate this angle very much, as I've never planned a trip like this before. So many other variables!
Agreed. I'm currently using the Slee newbie guide to buying a truck to get started.
I'm thinking head gasket, full driveline inspection, transmission flush, fuel system flush and parts and fix a few nit-picky things and spend some money on accessories, although there isn't much there I need.
I just ordered this book below. 4th Edition and apparently the greatest book for overland explorations from 10 miles to 10,000 miles, highly rated. I have never seen it but going by others recommendations. I am learning about this stuff as well.
http://www.exploringoverland.com/publications/vdeg4
Have you looked into getting a fridge/freezer? I just started looking into them and it's pretty expensive. Expedition portal haa a good review on some fridges
There are some great threads out there on this - if you search you'll find them. I use goggle, put your search terms in, add 80 Series and ih8mud and it will pull results from the board. I seem to get more specific results using this method vs the on-board search function.
So -
Look at your respective mileage and search for the Service interval listing for your truck. Start by making sure you are up to date.. If you don't know it was done or have receipts, it probably wasn't.
Some items I did to maintain reliability -
Tune up - All OEM Parts including plugs, wires, Cap, rotor, PCV, hoses, Fuel Filter, Belts, AC Pulley, the list goes on....
Baseline all fluids, get your trans flushed and filled, get your Radiator flushed and filled... Change your thermostat, change your radiator cap..
Brakes - Flush with new fluid and look at the condition of your calipers and soft lines. Replace if needed.
Soooo much more - Search and Read this forum.....
Some things that leave people stranded -
Fusible Links - Like $5 and if you wait for them to go bad, you're left somewhere. I have a new spare as well.
EFI Relay - I replaced mine and carry the old as a spare.
PHH - Pesky Heater Hose - Search here and replace it - Again will leave you with a bad trail fix situation
Rear Heater and Lines - I live in the south, but most of these lines are starting to rust away and if they rupture another bad trail fix. I just removed and bypassed mine.
Heater Valve on Firewall... When the tube that the hose slips over finally cracks and gives way, you blow all your coolant all over the engine compartment. Another hard trail fix.
New Coolant Hoses x 3 - Not expensive, but hard to tell if the old ones are bad until they let go... At that point, well, you get it...
Make sure battery and charging system is up to snuff.
Wiring Harness next to EGR Pipe... I wrapped mine with High Temp exhaust wrap. This harness on many vehicles comes into contact with that exhaust pipe on the EGR system, burns through the protective covering and some wires... You start to get electrical gremlins and will make you crazy chasing sparks....
Then start looking at maintenance items at mileage - Front Axle Service, get your drive shafts lubed and make sure they don't need services / new joints. Head gasket time? New Shock and Springs if original. Rear Axle Service....
Some words to leave you guy's with:
These are amazing trucks. Get them baselined and fix whats broken. Listen to them... These trucks will tell you whats wrong usually long before they will leave you stranded. If you don't neglect the things they tell you, you'll enjoy your trip and get back home.
Search CDan's cost of ownership thread. This will give you some insight on these trucks and what it costs financially and emotionally to keep them running at a level we expect.
Get a service manual. Either buy one or download one. Learn to use it and take it with you when you travel.
Search "80 Series Must Have tools"... Get your tools and carry them with you.
Don't expect to buy a $4,000 80 Series and think you are going to beat the Sh** out of it and it will never leave you stranded. If anyone thinks that, grow up. These truck need maintenance and for those of you who are younger than the age of your truck read CDan's thread.
Its easy to get sucked into feeling like you have the most capable SUV on the planet and believe you are not going to have to maintain / fix / replace a bunch of stuff. I forgot to mention that parts for these truck are getting scarce and those that are available are not inexpensive.
Finally - If you don't maintain your truck and it does crap out and leave you stranded, please don't come here and start bitching. There are so many people on this board willing to help you if you just come and ask questions. People here will even leave their homes in the middle of the night to come help you get back up and running. I've never seen that before.. Its a humble community that is willing to teach and share decades of knowledge if you "Search First", then ask politely.
Ive missed so much, but hope this helps you guys get started...
Best regards,
John -
This is a good question. I keep different checklist for my different outdoor activities because there are no stores where I end up. My camping checklist is basic, nothing more than what you probably have. I need to develop a maintenance checklist for trips, so I'm looking forward to the responses. Boltripper's response is one of the best, thanks John. On a side note, what's important for me may differ from someone in Africa, Europe, or Colorado, so it's helpful to put your location on your profile.
from person experience - check (replace?) your starter......
considering the back woods - mountain fire roads - no cell service - no car traffic - 10+ mile walk to any civilization places I go fishing....
although my started "died" when I was at home - indeed if I was on a fishing trip (alone) - I would have been fuxed (properly).
and lest you cruiser is a top a hill - with no functioning stater - aint no way you going to be able to crank over your engine...
bf
I don't buy into the "head gasket as PM" thing. It's a "fix it when goes" thing to me.
Thanks, that's good to here. I asked my dad, who used to be a mechanic, said the same thing. It's not that I don't trust him but just wanted more opinions on the subject. I have to budget wisely to make this cross country trip happen. which I'm hoping to take about a month off from work.
And that's certainly one way to look at it. I don't disagree, but probably won't roll much past 150K as my luck would have "It go" in the San Juan Mountains.. That'sthe risk we take and also the pleasure we have as adults that can make our own decisions with regard to what and when we complete maintenance on our rigs.
I'm PM retentive... Aviation has killed me for just letting things "Go".. Sorry, but if I'm at 190K and taking a trip next summer to Colorado, I'm going to do my HG prior... I do however appreciate your take on it..
J
My preference for being as independent as possible is why I went with the diesel manual, batteries fail, starters fail, alternators fail, I get one spanner from the tool roll two minutes later, and I roll the car forward three feet and drive home.
Hard to beat old school diesel IME.
regards
Dave
Thanks
Wow I'm planning the same, if I can get away for a month next spring, and it will be the longest trip I've ever been on by about a factor of x10. NY to LA, for starters, and then down through Baja for a week. All solo! So I'll be watching and learning from this thread hopefully.
When are you leaving, maybe we can convoy? :)
I prepped my high mileage 80 for a 10K mile road / overland trip last summer. It went off with out a hitch. Details of vehicle prep, planning etc can be found here:
https://forum.ih8mud.com/threads/prepping-a-high-mileage-80-for-a-10k-mile-road-trip.782671/
I did address the HG for peace of mind - happy I did as it stopped oil consumption issues. A fridge was indispensable as was safe, efficient cargo management.
@Overland Tailor 's list is pretty spot on IMO.
Planning.. Find great trip reports and engage with the authors and locals. This lead to great destinations. Expo, Wander the West, ADVRider in particular. Also get all the Benchmark Atlas's you can - they are clutch. Lastly - don't cling to a hard itinerary and take as much time off as you can.
I read pretty much all of your thread with great interest. I'm in Ohio and am planing a similar but slightly scaled down trip this summer. I haven't had my 80 long enough to trust it for such a trip nor will i have the time or money to get all the PM'ing done in time. We unfortunately will be taking the wifes CRV which was brand new as of August. Hopefully in a couple years we can do a bigger trip in the 80.
Your a mechanic. Seems like you have all bases covered. I think your good to go. I just did 1085 miles for Lafayette, La. to Tuscumbia, Al and back for the 2015 Mardi Krawl. The only thing I should have check was my freon. I don't use it when I drive around here, but apparently I have a leak because that s*** wasn't working. Glad my wife decided to stay home, because I would have not heard the end of it.
