So I think I finally found my shake/hop in my 1996 80.
I'll try to make a long story short. Last year I moved up to 5.29's and 5 @ 37x12.5x16 Interco Trxus Mt's.
The 80 drove smooth prior with 315's. I ended up with a shake/hop at 65ish and up. Shake always felt like it was in the rear even after a rotate. I don't drive too much on the highway but I do make a few long trips for wheeling events every year.
The tire shop I normally use mounted and balanced 5 tires on OEM wheels for me in May 2014. They used a Hunter machine with NO road force. They never said there was an issue with the tires so they are good, right?
I've put about 4k miles on since then. I have also replaced a bunch of parts trying to stiffen everything up like new. Including metal rear adjustable arms, rear shocks, few alignments, and most of all going CRAZY about my rear tire carrier bouncing along.
The rear carrier exaggerated the shake. It is a 4x4 labs rear bumper with single swing. The 37" tire is just too heavy for the 2x2 main bar for the single swing. It just twists the bar. After many hours of brainstorming ended up using a strap to a custom mount which keeps it nice and tight. This really made the shake/hop manageable since last year.
So someone started up a thread here on Mud about balancing beads. I hi jacked the thread after hearing someone mention "ROAD FORCE BALANCING". Sorry for the hi jack btw. I quickly called my tire shop and they had the Hunter Road Force machine there. I drove down and they started checking all the tires.
AND I have 2 tires out of 5 that are junk. They failed road force. The machine showed there where two small spots on each of the tires where there was too much weight....Like an Egg. No matter what they do at that point the tire will always have a hop.
So I called 4wheelparts.com where I bought the tires and they said they are still under factory warranty. I just needed to take a picture of each tires DOT # and send a pic of the receipt from tire company stating the two tires and how much weight they would take to balance out using Road Force. Then they will send me out two brand new tires!!!
The tires where out of balance by 64 oz. on one and 48 on the other.!!!!!
I posted this thread because I learned something new in this event so I figure I would doc. so others might save the time and hassle of a bad tire directly from the factory.
Thanks to Chitown for bringing up the road force balance over in the other thread!!!You the man.
Thanks to ToolRUs for pushing me along with great info over in the other thread.
ALWAYS HAVE LARGE OFFROAD TIRES ROAD FORCED TIRE BALANCED.
