Are the Roadvisions from AUS only combo tail/turn/brake/reverse light available that will work for the dual swingouts orders? October 23 is the soonest it will arrive if i order today. My bumper will arrive late September and will have it installed. Will i be able to install the lights even though the bumper is already installed?
In my research the Roadvision was the only 3-way option. Not like you have to use a 3-way, but I wanted the orange. The lights I received quick just a couple days from Jason (
@TRAIL TAILOR )because he had in stock at the time. The nice part about this route is James at RLC already has the cut template and brackets he made for us. Anything other he could do, but he'd most likley want you to ship the lights to him to fab the brackets. Here is the info i passed onto another member:
For the lights i ordered from Jason
@TRAIL TAILOR and he shipped them straight to James at RLC. Roadvision 3-way lights BR200LRARW. Same as Kaymar and Dissent and Trail Tailor use. Jason also sent James the CAD file he uses for the cutouts and the brackets to hold the lights, but James ended up just making his own design once he had the lights in hand. You should be able to have him just do the same as mine, as far as i know, i was the only 2 swing 200 order with him.
As far as wiring goes you'll need one of these:
Buy Curt 56196 at JEGS: Curt 2 to 3 Wire Powered Converter Module Used For Towing Vehicles Behind RV
www.jegs.com
With the Curt relay, you should be able to get the correct turn signal (orange) separate from the red brake.
Any 2-3 relay will work, the Curt is just the one I found. Unfortunately, most stores sell 3-2 relays (I tried about 10 local shops), the opposite of what you need. Let me know if you have any questions,
@A10Driver was my resource on the wiring
