- Thread starter
- #21
Adjusting pinion shaft depth by removing some shim thickness to result in a backlash of 0.75mm. Although contact was evenly distributed, without "real" torque applied, I didn't feel that great about it. Coast side was a little intense too.
Rear Axle Final Result a few years later... The installed driving result is no noise or whine on drive or coast. Success.
Pinion shaft shim setting shallow.
Pinion shaft torque: 200Nm (spec 196-235Nm)
Final measured overall starting pre-load: 3.5Nm (Spec 3.5-5.2Nm)
Final backlash: 0.48mm (spec 0.15-0.20mm, but the resulting contact did not work, plus worn gears, etc.)
