Right Front Shock Replacement
@NellieFJ40
Thanks SO much!
You might be able to help me out one more time also. Do you know the torque values on the castle nuts and large top nut? I've looked at the FAQ but am not sure what's what.
If the "large top nut" is the nut that holds the upper shock pin in place for the front shock towers, I would replace the lock washers (94512-01600) and just tighten it snug with a 1/2 drive ratchet handle.
Regarding the castle nuts, you don't torque them; my understanding (others, please chime in!) is that the concept is to tighten them up to slightly compress the rubber bushings, align a castle slot with the cotter pin hole, and pin the nut in place.
