Rhino Lining Removal?????
Yes... I spilled a bottle of blue loctite on my herculiner...it lifted no problem a few days leter...so some stuff will eat it.
WORST THING YOU'LL EVER HAVE TO DO. Depending on thickness you can somteimes get an edge and peel.. otherwise industrial wire wheel. Messy.
The PO covered the outside of mine with some sort of liner. Some of it I was able to use a razor blade and peel it like a decal. On the parts that wouldn't come up with the razor I used Airplane Coating Remover from Kragen.
If you have a c02 tank turn it upside down and spray some straight c02 on it, Then hit it with a scraper, Do not use the wire wheel as it will make a huge ass mess. You friend is the cold, It will help to stiffen up the lining and make at brittle.
Dave
