So I seem to have run into a little hiccup I now need to solve. I’m installing coil overs and 80 series arms on the front of an Hj47 troopy. Axle is a full width Dana 60. My plan was to run the typical y link steering on this but in rhd config. I can’t run high steer arms on it as it has clearance issues with using factory steering arms. I’m looking at notching frame for tie rod on full compression.
ok so here is what it looks like.
on a typical lhd truck the tre’s sorta work like this
For my RHD troopy they need to flip....
So the trouble is this moves the drag link behind the tie rod due to the taper on the one tre that is made to accept the drag link.
Now I think I have a few options....
1. ream that tie rod the other direction.... wouldn’t have full contact as profile would be an hour glass shape. Could maybe weld it up and back machine it after..... sounds sketchy.
2. try and find a rhd version of that tie rod. It didn’t jump out at me at first blush.....
3. Convert that end of the drag link connection to a heim joint so I weld tabs to tie rod to accept the heim.... that could be best plan. Still have y link then but one heim and the rest tre’s.
Anyone solve this or see it solved on aussie computer rigs. What do they run?
