RHD conversion - 1990 3f petrol engine
South Africa
hi,
need your help with ideas on who can convert 80's series LC from RHD to LHD and also deal with the papers and license.
the car is located at south Africa but it doesn't have to be over there.
thank you!
Where are you going to import it?
Do you just want to meet legal requirements, or do you want to completely convert the interior to LHD as well?
I am in South Africa if you looking for help this side. There is a Left hand drive on gumtree now for sale. Also a 1990 3FE VX
Guy will not get much for it as it can’t be registered here.
The idea is to import it to Israel. The thing is that i cant import RHD car so i need to convert it to LHD intrior and in papers...
@BarHav I would hold out for a LHD model like @Grant Woodbridge is suggesting. It will be a LOT of work and cost more than the truck is worth to do this conversion. What is your end-use? Is it really worth it?
It's probably not with it unless you have a line on a wrecked LHD model that you can get really cheap. I think I've read that you have to swap the front axle (and the transfer case?), then you obviously have to move all the controls over, swap the dash, and you'd probably need most of the LHD dashboard wiring harness.
Buy a Left hand drive. Converting would be a real pain and the paperwork will probably be worse. You would literally need a second land cruiser donor for left hand drive parts to make it left hand drive.
Transfer case, no. The rest yes... plus the firewall is different and I'm not sure the frame is guesseted on the left side for a steering gearbox. The heater core wouldn't work, the AC core wouldn' work, the dash support wouldn't work... just too many things that require changing. A donor is definitely necessary as is a thick wallet or an extensive set of fabricating skills, equipment and time.
