I've been working on this Radio Frequency Interference (RFI) noise problem for about a week, talking with Alan at K0BG.com but I thought I would post here as Alan has no experience with cruisers and you all do
In short, the High Frequency (HF) bands from 0-54mhz transmit and receive crystal clear with great range. However, the Very High Frequency and Ultra High Frequency (VHF/UHF) bands from 100-500mhz and up transmit crystal clear and range seems correct, but the receive has a low level static that doesn't break through the normal squelch setting, but definitely is heard once a channel has transmission coming through.
I had my Icom IC-7000 installed in my 2002 Yukon XL Denali using a dual band Larsen NMO 2/70 for VHF/UHF (2 meter is the ham band that ranges from 144-148mhz and 70cm is the ham band that ranges from 420-450mhz) and a dedicated Firestick for 10meter (ham 28mhz) and interchanged with 12m (ham 24mhz) , 20m (ham 14mhz), 40m (ham 7mhz) as needed. The IC-7000 has two antenna inputs, so I keep the dual band Larsen on for the VHF/UHF bands and add the Firestick for the HF bands.
I moved the entire setup to the cruiser about a week ago. I left the Denali setup for an easy move back, but I used identical coax in the cruiser (Larsen NMO to Amphenol soldered PL259 for the Larsen and Firestick Firering to soldered Amphenol PL259 for the Firestick). I moved the actual coil and whip over to the cruiser and put a rain cap on the Denali NMO. The Firestick is on a quick-disconnect 3/8" x 24 stud on both vehicles. The Firstick is on my front ARB bar, which I spent a lot of time getting a very good DC ground and bonded with 1/2" braided strap to get a solid RF ground. The ground (image) plane remains poor - relative to a hole drilled in the center of the roof, but is adequate. There are no problems on HF anyway, so it is good enough. The Larsen is on a Larsen hood channel bracket on the PS about mid-way from the cowl to the front edge of the hood (same as the Denali).
I purchased a second Icom power cable from Ham Radio Outlet hamradio.com ($$$$ ouch) and ran it directly to the second battery on the cruiser (just as on the Denali).
I set everything up and the HF side (Firestick) is working great, just as in the Denali. But the VHF/UHF Larsen side has some minor RFI only when the cruiser engine is turned on. Its not that bad, in fact, but for seeing it on the main display I don't think I would have initially noticed it. It is below the squelch level I normally use. When I start the cruiser, the front display meter bounces from a low of 4 to a peak of 9 and an average of 6.
If I disconnect the HF antenna line, no difference on HF or VHF/UHF. If I disconnect the VHF/UHF antenna line, HF remains great (no surprise) and the RFI disappears (not really a surprise there either, I just wanted to make sure it wasn't coming in the power feed or the front end).
I've done a fair amount of bonding using 1/2" braided straps: two on the hood (one each side by the hinges); one on each of the four doors; I haven't done the rear hatch or tailgate, but I suppose I could. I have a single strap on the exhaust near the resonator.
Here is my suspicion: My cat got banged up pretty bad while wheeling this past weekend. As a result, the Y-pipe is loose where it mounts to the manifold (I can hear an exhaust "gurgling" leak there), and I the bracket just after the rear cat is completely broken (I can also hear it rattling around). I suspect this seperation from the frame and vehicle ground is the source of my RFI - I'll try to get it welded and add another strap by this weekend.
I know moving the same setup from one vehicle to another doesn't allow for comparison (even from one cruiser to another), I just added the details above for completeness and so it is clear that this is not a radio problem.
Alan K0BG thought the source might more likely be ignition related, but I figured if that was the case at least one other cruiserhead would have mentioned a problem.
I recently did a major tuneup, so all my wires are new (factory OEM) and the plugs, cap, rotor, etc. . . .
Am I missing anything? The RFI isn't affected by the AC, cruise, or stereo. The Digital Signal Processing (DSP) Noise Reduction (NR) on the Icom does make a marked improvement, but now that I see it on the display I know it is still there (I CAN also hear some static on the VHF/UHF stations that was not there in the Denali). The Icom noise blanker (NB) which would normally reduce or completely suppress alternator whine, has no affect on the RFI.
So, any thoughts from the cruiser hams?
So I'll definitely be looking into your suggestion on the alternator ground wire (is this the single large gauge wire coming off the top rear (cab) side of the alternator?).
. So the plan is to connect with him sometime in the near future (hopefully this week) and run by his place to have my cruiser spectrum analyzed (sounds wierd). My guess is that the alternator and/or its ground is going to be the biggest source, but the plug wires may also be close (I really don't want to wrap them like Groucho as that looks like one heck of a pain). I say this b/c, not having an oscillascope or spectrum analyzer, I tried a low-tech method of connecting the vhf/uhf coax but leaving the antenna coil and whip off and then moving the NMO connector around various points of the engine and ECM. Oddly, I still recieved several strong local signals (local police dispatch for example and the repeater that is a few blocks away) but the zero RFI. But when I passed the NMO mount near the ignition wires there was about S3 and when I lowered it to the alternator (maybe touching it) it shot to S9. The ECM, cruise and various other things produced nothing. I know this isn't scientific, but that is what my guess is based upon. I didn't look into the fuel pump as a source, but now wonder if I should have.
you were correct. Nothing coming out of the ECM, exhaust, alternator, or anything else in the engine or under the dash (except the 11m antenna coax that I forgot was on the DS under the dash and then got real excited when I ran the probe over it and the display went crazy
