Retarded Bird 2
OC, CA
Ok, slightly different retarded bird than our original thread in this section.
We've had what we 'think' is a woodpecker under the eves of the side of our house constantly pecking away for quite some time now. I took a look a couple of weeks ago and didn't see anything outside of the bird flying away. It was out there again today and the wife went out to look. She called and said there's a rather large hole in our stucco the bird has opened up for a nest! Damn bird must have one hell of a hard beak to have gotten thru the stucco siding on the house!! :bang::bang::bang:
Wire mesh, stucco repair and paint will be the easy part.
Now the question - how to keep the damn bird from coming back? I know moth balls will work to dissuade skunks from living under a deck. It worked! Using the same method and logic, I've gotten rid of a raccoon that dug thru a shake roof at my old house to nest in the attic. IIRC I was told that spraying ammonia on the tree trunk it was using to get to the roof would add an add'l deterrent to moth balls spread throughout the attic. It worked!
What's going to deter this damn bird? I don't know yet if the hole is in an area where I can just rig some screen to prevent it from getting to where the current hole is or not until it decides to go nest somewhere else.
Maybe the bird is attracted to all the guys peeing in your bushes?:D
More seriously, how about a pellet rifle?
Too funny - wish the bird would peck away at the guys first. :p
Don't own a pellet gun and illegal to discharge in town regardless. Bird flies away to quickly to get a shot, even if I could.
Many peckers are protected, harming them is a bad idea.
First I'd hose down the stucco to make sure there are no small insects living in there. If mothballs have worked, try dissolving some in water and spraying the walls.
My pecker is protected and hurting it is a bad idea. Nobody likes a hurt pecker.
