Restoring Factory Flares
flat earth Midwest
Trashed the left rear flare set back couple of weeks ago in a fit of impromtu trail rash. Replacement factory parts will be on the way from arcteryx/CruiserYard soon. I know I recently saw a thread that discussed here to acquire the black packer strip that goes between the body and the flare, but an hour of searching failed to turn it up.3331413eI noted what seemed to be some residue from adhesive left behind at the top of where the flare was attached, but may just be old grunge.
Can someone point me in the right direction, where to get the packer and whether it needs to be bonded to the surface with something?
Also, any secrets to the various fasteners used to attach everything (the mudflap, ,ttogether on a non-running board truck. ? I have most needed
Thanks!
@SUMMIT CRUISERS has the gasket but in black only , double check with him. I just got some myself to replace my nephews rruck.
Not hard to put it all back together, reference your other side. Holler if you have questions.
You're looking for the fender welting. I did this last year when I had my white '95 repainted. They were available in every color from the dealership back then. I had to paint the fender flares, they were only available in black or grey.
There is no adhesive between the welting and the body, or the welting and the flares. The body bolts should come off and go on easily, unless you have a rustbucket. I'd replace any fasteners that wouldn't play nice; they're cheap. Any nastyness in the joint can be removed with the prep solvent body shops use; comes in a spray can, from various manufacturers. Your local dealership body shop may give you one if you ask nice.
HTH
Thanks for the help and advice everyone. I suspect the white residue under where the old welting went must've been wax residue or something. It buffed out, unlike some of the other damage:(
But I surprised myself with getting things straightened out with some hammering and pulling -- and my trusty Toyota bottle jack.
Somebody needs to create a rare earth magnetic mounting kit for the factory flares. Snaps into the rivit mounts. Something plenty strong enough to hold the flare on the rig, but removable with a quick yank (or bump from the tire).
Okaaaaay, but I had no problem with getting the flare off quickly. Flicked right off there at 70 mph...
The new gasket is still available from mrT. It has the equivalent of 3m foam emblem adhesive on its entire length from Toyota to ease installation and hold it in place.
The new gasket is still available from mrT. SNIP
Excellent!. I'll see if Mr. T's price for one can beat Summit Cruiser's price for four. I might be depressed...it's not the cost difference, whatever the winner may be on that, so much as I hate having lots of leftover material. When I was 18, caching stuff I might not need for years made sense...now that I'm much older, I just end up tripping over it.:rofl:
I think front "wheel opening pads" list at about $34 and can be had for about $23. Rear is slightly less but you need 2 ( cut to size).
How does it ease installation?
I just stuck them on the flare and then put the flare on without the pad popping off. Perhaps there was no intent to make installation easier, but I definitely noticed how convenient it was, so like most things Toyota I assumed they were thinking ahead.
Summit will provide welting for just one corner at a very nice price, beating Mr. T's price. Should be easy enough to get it to stick as needed with a little hillbilly engineering. But it's always good to have options,
arcteryx got me a nice set of take-off flares for my left rear quickly. The front one for the door is a nice shiny white. No problem lightly scuffing it to take primer and paint. I am wondering if anyone has a recommendation for a good primer that works well over the plastic, since the flare is somewhat flexible?
The rear section of the flare that mounts to the body presents a bit different issue. The black paint finish on it is rougher, maybe a repaint by someone who had an even bigger issue with orange peel than I do at times when spray canning? Or did Toyota once offer flares that have that rubbery look to them and this is a factory variation? In any case, do I sand this to smooth it or try to remove the existing finish? As in my previous question above, I don't have much experience painting anything but metal and I want to get this right over the plastic on the flare. It needs some TLC to get it smooth enough that its finish looks the same, smooth as the other piece.
arcteryx dropped me a PM that sanding will work, so I whipped out a succession of 150, 200, and finally 600 grit paper. Things cleaned right up. Looks like the rear part of the flare was originally white, as it happens In any case, the surface quickly became smooth and I then wiped the dust off and prepped for primer. I used Rustoleum #285011 Universal Bonding Primer. The two flare pieces now have a matching smooth finish that is uniform, slick, and ready for topcoating.
