Restoring an FJ55
Grand Junction, CO
Website
westernslopeanglers.com
I have had my eye on this pig around the corner from my house for about 3 years now. Not sure what year it is or anything else. All I know is that it hasn't moved in those 3 years. I am sure it has rust around it and not completely sure on how it runs or anything at all for that matter. The tires are flat and it's is almost sitting on rim.
At the same time, I am looking at getting rid of my boat. Mainly because I don't have the heart in me to restore that. The pig would be a different story. It would be a much more worthwhile project for me to take on.
I was thinking of going over to this guys house and see if he would just want to trade the pig for my boat. Even Steven. I have no clue if he would even do it but before I approach him about it, I would like to know what I am getting into.
I don't expect to have the 55 up and running in a week. It would be a project. Probably a year or two in the making. But regarding rust and various engine/tranny/suspension stuff, would I be biting off more than I can chew? I would mainly be looking at it sharing time with my 60 for daily driving duties. Don't really plan to go wheeling in it or anything. Nothing rough. Just basic stylish transportation. No major modifications or anything like that either. Pretty much just keep it stock with maybe some suspension mods and larger tires.
thanks,
I would head over to the 55 section and spend some time reading through the volumes of info in there on rust, condition, value, availability of parts, etc.
They are fun trucks, but $$$ for a clean one and clean parts!
:beer:
Good luck!
-Steve
:beer:
Good luck!
-Steve
Thanks. I didn't even know that was there. :confused:
That's a real big post for one question. Could you clarify?
How good are you at wrenching on the 60?
thanks,
I guess I am alright if I have a little help. Replaced my clutch last winter in 20 degree weather outside laying on the concrete.
I am 70% comfortable with the engine/tranny/suspension parts. Not so with the body.
For instance, how do you cut out rust and replace body panels, etc. etc. Interior work, etc.
A Pig is easier to wrench on than a 60. Body parts are harder to find though. Cutting and patching, I can't say...
Heat is your worst enemy for body panel patchwork. Only use a plasma for quick turning cuts you can't make with a saw or cutoff wheel. If you're using a mig on sheetmetal, only spot weld 3"- 4" apart, let cool then repeat. Too much heat will easily warp the panel. 2 grinders are best for cleanup - one with the heavy disc & the other with a flapwheel or med duty grit paper. I'm rebuilding a PIG right now & I'm finding out I don't have the patience for letting the panels cool down, therefore I've got some sheetmetal bending to fix..... Good luck on your buildup!
