Resistance/Spot Welding
Woodstock, GA
I haven't noticed anyone talking about using a spot welder to replace body panels. I was wondering if thereis a reason? Is the gear too expensive?
It seems like it would be much easier than using a welder t run a bead on sheet metal, and it's what the factory used originally on the body parts. I was wondering because I have bad eyesight and I thought I might not be able to do any "real" welding myself, but I think I could handle multiple spot welds with no problem.
Thanks guys!
and you don't "run a bead on sheet metal" its damn near imposible. use a nice mig and take your time.. unless your shooting for extreme warping i wouldn't try'n run a bead on it. Get a thicker tint on your welding helmet as well and it shouldn't bother you. you can still do "spot" welds with a mig. if you mean by just tacking it in place and moving to the next section of the body panel to avoid over heating it. someone will chime in with more knowledge but thats about as much as i know from what i've done.
The panels were originally assembled with electric resistance or spot welds, so this is a good way to do it if you are replacing the whole panel. They do make portable units, so maybe you can rent one, but you would need to make sure that the jaws have enough "reach" to get to all the places you need to weld. We have a real nice one at work, but it is not portable and I can't imagine trying to manipulate the entire chassis just to use a spot welder. It works great on small pieces like tail gates. You can also use plug welds to join panels (drill a hole in the top piece, clamp the pieces together, and weld to the piece underneath), but these don't look like the original electric resistance spot welds.
You might try using the new style of auto-darkeng lense/hoods that are on the market. They are still a little pricey, But the one that came with my small Hobart mig set-up has helped my ageing eyes considerably .
What Pin_Head said about spot welding. Also, it's much cheaper to repair existing panels than to buy new ones, if new ones are even available; not all are.
Along with the auto-darkening helmets there are dioptic lenses sold for most welding eyewear that can help if your eyesight problem is the sort that makes you require reading glasses. They're available in most any of the usual Dr. Edell drugstore rack magnifications. (ones for Miller helmets are proprietary, BTW).
Also most of the helmets have room for your glasses, I think. I don't have direct experience of that.
Thanks for all of the info and suggestions, guys. I had an eye disease when I was 21 and I'm mostly blind in my right eye and I have a spot on the center of my left one that I can't see out of. I've learned to kind of look "around" the spots for most things, but small detail work is more difficult. That's why I thought of the spot welding. It allows you to set up the weld in advance and then hit the switch after everything is arranged. I thought that I might be able to do that, but I didn't know how the original factory welds were accomplished. Sounds like it isn't feasible to do it at home.
A lot if good info about MIG welding, though. I may try to rent a welder and practice some time. I hate to buy one just to find out that it's beyond my abilities. I'm a bit of a perfectioninst and want my rig to look right when it's finished. I might be better off saving my money and paying someone to do it right.
I looked for a Tech school to try to take a welding class, but it seems like all of the schools around here have become 4 year colleges and don't seem to offer classes like that any more. At least not that I have found. If anyone knows of a school in the Atlanta/Alpharetta/Roswell area that does, I'd appreciate the info.
Thanks again!
Thanks again!
I just took a class at a Community College. Are there any CC's in your area? I would bet classes are just getting started.
I have an adaptor for my arc welder that uses carbon rods to produce a carbon arc (to heat for brazing).
It is designed to also be used to do spot welding (from one side).
It works ok, but because it's all from one side the panels need to be a good fit before welding.
Check out HarborFrieght.com . They have two spot/resistance welders (110v and 220v) that may work for you. Butt welds are difficult with these type of welders like Pin Head mentioned.
