Reproduction Labels Project
Mine is a 1996 and our “important vehicle info” decals have slightly different barcode numbers and I assume part number in the lower left. What year is your cruiser?
97 on this set of decals.
@Shoulderleen any progress to show?
i have these going on now ...
there NOS OEM TOYOTA JAPAN Spec. ,
heavy duty chrome foil types
i got a bunch
fits well on my
3FE
Hate to say it but I haven’t done anything related to this project lately. Started working on some things that would make the reproduction process a heck of a lot quicker but ran into some IT constraints… then my day job got really busy.
For the sake of transparency, right now my LC-related priorities are:
1. AC Repair/Replace
2. Seat heaters Installation
3. Enfig microphone project
4. Security system indicator light led upgrade
5. Decal project
Cheers
So see you never. Got it. 🤣.
Well, time I have my friend. When you get after it, bump this thread. Good luck with your projects!
5. Decal project
Cheers
what's wrong with the OEM factory VIP red LED status monitor & glass breakage sensor sub. assy. ?
ok , yes i see
perhaps i could help you " switch " your plans , especially if i sparky'd it up with a max-lumens LED update bulb too ......... :cool:
Quick update on my priority list:
1. Brake Booster replacement
2. Labels Project
Brake booster goes in this week, then I will resume the labels project.
Also, the label paper I recommended has not held up after however long since my first post. either I will have a print shop make a bunch for me and sell those on Etsy, or I will make the designs freely available as a contribution to the community. More to come.
5. Decal project
Cheers
I see your IT constraint.
Your computer is obviously rearranging lists in the reverse order!
You should fix that! :flipoff2:
I have nothing useful to add, I'll see myself out :oops:
In the world of industrial graphic design, the terminology for what I pipe-dreamed up below is called “ Inversion “
these are my 1st rodeo with a non-brushed metal foil media , I kept true to the very subtle and very mild metallics in the factory OEM toyota original version , so hence inversion …
This is a OEM Toyota Label / Decal , i affixed to the same 1FZ-FE 80 series as my custom sema-spec,. concept vision ( Silver / Chrome foil Inversion ) Engine Name Plate No. 1 ..
the radius is perfect , and the new modern age 2025 non-foil media TOYOTA is using now on this particular label / decal is super user friendly , and super heavy duty as well . it's made in Japan as well .........
i personally Dig the white background w/ med. blue color text / font . it stands out , pops to the eyes and gets your attn. as it should ....
i have installed one on my 3F-E , Bliss is the word that first came to me ...
The front face Power Steering label / decal is my reproduction work , it is metal foil also and heavy duty tough as nails solid .....
the USA-SPEC 1FZ-FE FZJ80 did not come from
PLANT A11 with the top semi-circle label / decal , i am unsure about any market region ones ?
The FJ80
3F-E equipped early one 1991-1992 All did , but it was the older metal foil type , the current rendition of a new OEM TOYOTA Power Steering Pump Assy. has the new modern age 2025 white / w blue text / font on the now BLACK Zinc Plated metal reservoir
i have concluded that all TOYOTA OEM Power Steering reservoir's of this same size ( round O.D ) will nicely accept the contours and radius of this now permanent addition to the store i show below ....
matt
1FZ-FE BELOW :
3F-E BELOW :
