replacing the passenger side light marker
Albany, NY
Hi,
My PS side marker (the white light that blinks when you lock and unlock the vehicle with the remote) is out.
I bought the bulb for replacement but I can't figure out how to get to replace it.
Can anyone provide some pointers or instructions how to replace it?
Please note that it is a 96, but since I have a dual battery setup, the second battery and battery tray are installed.
It is not clear to me if the battery tray needs to be removed to gain access.
I also looked to see if I can access it from underneath. But I can't see anything.
Help is appreciated..
Rami
From what I can tell, there is no such thing as a 'factory' alarm on a '96. There were quite a few dealer installed ones, lots of aftermarket ones, etc...
Also, I'm not aware of any stock 'white' lights on a '96 other than the headlights and the reverse lights - so, I'm not sure what 'white light' you're referring to.
Also, there are no true front 'side marker' lights on US 80s, but there ARE on non-US spec 80s and there have been several people who have installed them. Those sit in the fender. There are rear side marker lights - but those should be a red filter - and they have clear screws on them for removal.
So, that puts us with the wrap around corner lens and the flat forward-facing light underneath it.
The wrap around corner lens is removed by opening the hood, removing one screw from the top inside corner of it, then pulling it forward. Pulling these out can be frustrating. There isn't a real good way to get a grip on it.
The flat amber (some have changed the cover to clear) light underneath the headlights isn't hard to get to - so I doubt that is the issue.
What would really help is if you can either take a picture or steal one from someone else's post and put an arrow on it saying "THIS light".
OK. That is what I described as a wrap-around light above. "Front Clearance Light" is probably a lot more correct.
In the diagram you see the part identified as 93560-54016. That is the only screw that you need to remove. Once the screw is out of the way, pull the lens straight forward. It has a pencil sized pin on the lens that goes into a socket on the truck side. Think of it as a real tight pen cap. Don't go side to side with it or you stand a chance to break the pin. Be ready for it - sometimes they require a lot of force to pull forward then give suddenly. You don't want to break the wires and fall on your rear when it gives.
Grench,
Many thanks.
Just want to be clear, I unscrew the bolt, and pull the lens FORWARD, as standing outside the truck, and yanking it out of position to get to the replacement location.
Will do it tonight.
Rami,
This might help --> Slee - Indicator Light Modification (Toyota 80 Series Land Cruiser)
Remove the screw and then pull, prod, cajole, etc. that lens out. In the pictures on Slee's site you can see the locking pin that is fighting you holding the lens in place :) - You just gotta pull as best as you can straight out (away from the front of the truck) and muscle it out of there. IIRC the locking pins are on the lower outside corners of the lights so try pulling the most from the bottom outside corner.
HTH
Oh. Excellent. Now I know what to do.
The mod is excellent, but will have to be done some other time. I just want to get the light fixed.
Haven't done the mod either but best pictures I know of that show you how to get that light out. I've had mine out numerous times now and I still think every time that I'm going to bust something when pulling them out. Those locking pins can really hold the lights in there and like Grench says, there really isn't anything to grab on to when pulling.
IIRC the owner's manual also shows how to replace that bulb. I smeared a little grease on the pin when I replaced the bulbs on my wife's LX.
(Gray '96) In my case the DS light is near impossible to get out. The PO had bumped a deer with a damage multiplier on it. Everything still connects, but that corner of the quarter is just slightly tweaked - makes getting that marker out a bear and a half.
(Red '96) I changed the DS marker bulb in my wife's truck a few weeks ago - it wasn't nearly as challenging. It is still a bit disconcerting to pull on that lamp until it pops out.
(Sand '92) We don't have this one anymore, so I could be imaginremembering this but something I had noticed as a difference between the '92 and the '96... The '92 had a round rubber plug inside the front wheel well. It was in just the right spot to put a 1" wooden dowel 18" long through to nudge the corner marker. Was that just my imagination - or can someone with a '91 or '92 take a peek towards the front inside the wheel well to see if that rubber plug is there?
Many thanks to all.
5 minutes and I was done. It took a good pull, but nothing too hard.
Please note that this has been bugging me for months.
