Replacing the knock down cable?
Atlanta, GA
Has anyone ever done this?
The cruiser wasn't downshifting and after a quick search on here I went to check my knockdown cable. After inspection it frayed right where it connects to the throttle body and was completely disconnected.
I'll post some pics in the morning, but assuming I can't reconnect it as is how hard is it to replace the entire thing?
Any help appreciated, Thanks.
Yep I've done it. not terribly hard but you do have to access the Transmission it was pretty messy as I remember.
It was many moons ago you do have to make a metal plate you temporarily bolt in place to keep the accumulator
pistons from falling out of the transmission. Since you'll be in that far plan on a fluid change and new filter as well.
I think this is covered in the A440F service manual. I'll look at it this evening if you'd' like.
Thanks @BGarcia88FJ62, I had plans to flush the transmission so i guess now is as good a time as any. I just found an A440F Service Manual so I'll see if I can't find where they cover it.
Here's the pic too, to short to fit back in.
Finished this up a few days ago, I've been fine tuning fluid levels and the cable and have got it driving real well.
The one thing I did learn that cost me a few days is if you're going to drop the valve body to hook up the cable you're probably going to need new #1 and #2 Valve Body Gaskets in addition to the pan and filter gaskets.
Now I just need to figure out how to get the smell of tranny fluid off of everything :doh:
I just started with it fairly loose and tightened it up a little bit at a time until it drove how i liked it
