Replacing Ring and pinion question
Montreal
Sometime this summer i installed ARB lockers front and rear. I had someone do the work and in the process we changed every bearing and seal.
Now in one or two week i will be installing 4.88. I probably drove 1000miles since then. Since i'm not going to do this myself, what should i expected to be replace if anything? The pressed pinion bearing? some seals? or maybe nothing?.
It is possible to remove the bearings without damaging them. For the inner pinion bearing, you will need a plate type bearing separator and a press.
And a lot of luck...
I have a couple different plate style separators and have yet to remove an inner pinion bearing without damaging the cage...guess I do not have the knack.
Pinion kits are cheap...and it will make it very easy on your install wrench.
:beer:
what the heck are you doing to them steve? i've gotten a few off without any issues. only done a few though.
I don't know...
Guess I am an Fing hack...
Perhaps you should stop out here sometime and school me on a thing or two... ;)
:beer:
....i wish my tool chest was that full :frown:
What about seals? are there any one that always get damaged during removal?
Steve, I think the problem is that you're not using Harbor Freight puller plates. :)
Eleblanc, Ing's is right, Seals are cheap and it's bad ju-ju to reuse them. For that matter, bearings aren't all that expensive either.
The one thing you can't expect is that the guy who does your work save and reuse your parts for sure. He's probably going to be willing to do that if he can but shouldn't be expected to gaurantee that the job will be done satisfactorily that way. Don't try make him cut corners on the quality of his work, and if you are dealing with someone willing to cut those corners you might want to find someone else.
Thanks all for the response. The first guy who installed my lockers was the TLC guy around montreal. Unfortunatly i made him do the job a Thursday and friday prior for him leaving for holidays on the friday afternoon. I don't think he did a bad job but one of is mechanic helping him forgot to tight the two drain plug, stupid error but if i'd lost any of them conséquence would of been terrible with new lockers in both of them. So i decided to look for someone else and after a month of inquiry i was told that only one guy around montreal was the best trusted one for this, so i'll go there, its called "Joron". If i'd have the garage space and tools i'd venture doing it. But i don't and can afford having someone do it, but i'm very picky about who touches my BJ and very perfectionist to the work done on it. I was expecting to at least change both inner bearing of the pinion and maybe some seals. I'll check how much the seals cost and unless there are a fortune i'll change them all again. I'm kinda pissed that i didn't have the R&P installed at the same time i got the lockers in.
The goal of my question was mainly not to be over billed. If after 1000miles most of you don't tell me i need to change 90% of the bearing again, then i won't expect him to charge me those. Now i should not expect more the 2 bearings and seals kit.
Now i have a other dilema, 488 or 456? I run a 3B with H55, right now 255/85/16 Bf muds mesuring 33.5". 456 still bring my over stock speed. 488 brings my 2-3kph, lower then stock. Right now i had in mind to go 488 since i have both kits here and since i may eventually go to 35". 35" with 456 would set me back exactly how i'm currently running 33.5" with 4.11. And its bad with my poor 3B if i have head wind the 5th gear is unusable. any type of climb on highway i cannot sustain it in 4th, therefore its 3rd gear and 35-45 mph....
I hope you get that an honest mechanic may not be able to guarantee the reuse of your bearings. You may not know it but the fellow posting above as "poser" is one of the most experienced cruiser mechanics you could find in either country and if he says , which he did say, that he cannot remove the bearings with an assurance that they will be reuseable then you should not expect that yours can be removed and replaced in servicable condition. This is not to say that poser or anyone will not be able to remove bearings without damage only that as he may, so he may not, and rather than expectations you can only have hopes. Do you see what I mean?
About your power issues. Have you considered turbocharging your engine? If you look around in the diesel section of this forum you should find considerable information on that topic along with the accounts of several owners who have successfully adapted various small turbos to the Toyota B series diesel engines with very good result. Such a course might even alter your thinking about the need for deeper axle ratios and give a life to your vehicle which you could not normally have realized.....eh. :)
I hope you get that an honest mechanic may not be able to guarantee the reuse of your bearings. You may not know it but the fellow posting above as "poser" is perhaps the most competent cruiser mechanic you could find in either country and if he says , which he did say, that he cannot remove the bearings with an assurance that they will be reuseable then you should not expect that yours can be removed and replaced in servicable condition. This is not to say that poser or anyone will not be able to remove bearings without damage only that as he may, so he may not, and rather than expectations you can only have hopes. Do you see what I mean?
Maybe i didn't make myself clear, I know and that is why i expect to have those bearing changed. I have no problem replacing them with new.
That is on my mod/wish list, currently in order, get the R&P insalled, then get the OME spring and installed, next is probably 35" if the truck will fit in the garage, next is Orion TC or Turbo, both mods are about the same price. When i'm wheeling power is really not a issue, in first/low gear i can tie the truck to a post and unclutch with 4 wheel locked and it will dig itself a hole, and won't stall. Obviouly in the dirt not tarmac. But yes turbo is high on my wish list, but i have the R&P so i'll get them installed.
i did not think poser had ever been into a Harbor Freight :grinpimp:
