Replacing Oil Cooler Hoses
I am in in the colder climates from time to time and think of my oil coiler on my 1980 FJ40 as more of a warmer than a cooler so I have kept it on. The hoses are looking very old these days and I was thinking of replacing them.
I wonder if these hoses can simply be replaced with standard hose off the reel at the local NAPA store or are some of the bends too tight and I should find a formed hose if they are still available? What is the proper ID for these hoses? Looks like 1/2" might work but not sure.
Thanks,
Here's the relevant diagram:
early-oil-cooler-png.1296561
15777A is a straight hoses (despite the depiction in the diagram) so you can find something close in the auto store. OEM is still available.
15777C is a formed hose so you must get the Toyota part.
15777 is also a formed hose and discontinued. This is a problem for oil cooler equipped vehicles like yours (and mine). My shop is working on a reproduction. It will be available in a couple of months if you can wait.
While you're at it you might as well replace the 15777B pipe, which is likely to be rusted. By the time 15777 is ready, I'll put together a kit for replacing all of the these pieces. Everything is equally old, so it doesn't really make sense to do the job partially.
Is the 15777B pipe still available OEM? Looks like my 15777 hose was replaced at some point with a straight piece of hose that was curved into place. Does all these hoses have the same ID? If so, anyone know what it is? While I was in there, I noticed the heater hoses on my firewall aren't in great shape either. May need to address them at the same time.
Racer65: If you make a kit, will it be out of rubber or silicone hose?
Yes, pipe is available OEM. Your 15777 is that way because there is really no other solution.
Repro hose will be made of rubber. This hose fits in a tight area with 2 clamps around it. Rubber is more flexible and easier to fit for this application.
