- Joined
- Apr 16, 2015
- Threads
- 7
- Messages
- 68
- Location
- Austin, TX
- Website
- www.patricklanephotography.com
I have a silly question. My front diff is leaking like a five year old after a big gulp, with this said, I am going to replace it or fix it. Also it should be noted that it is also make a random clickish noise that sound like a tin can being toss around in a metal garbage can when I am on the accelerator at 1300 to 2200 RPM, note it is a random tempo and doesn't have any cadence. So I think I striped some teeth when I did a rookie move and moved the vehicle on with center diff locked and turned a little to the right. Tired to unwind it then by reversing and later with some suggested methods but now I've got this noise and a still leaking diff in both the front and back.
Could the noise be my center diff? Sound seems to be coming from the front.
Also,I located a rebuilt but I was under the impression that the stock gears are 4.11. Is this correct?
The seller is selling his for 375 with free shipping. Is this too much. He said "Its all stock. Never rebuilt. Bearings smooth as silk With 3:80 gears . I'll refund you $50. For yours. And you can keep the gears out off it. all I want. Is the case and drive shaft flange"
Kind sound like he is send me a unit with a problem if he only wants the case. Should I be leery?
Thanks for the help. I guess I can drop it and check to make I didn't strip the gears. Could the sound gust be bad bearings?
